# Sending CSV Data to MSSQL Server
**URL:** <https://discourse.nodered.org/t/sending-csv-data-to-mssql-server/24922>\
**Created:** [16 April 2020 06:14 UTC](https://discourse.nodered.org/t/sending-csv-data-to-mssql-server/24922 "2020-04-16T06:14:54Z")\
**Post date:** [20 April 2020 08:20 UTC](https://discourse.nodered.org/t/sending-csv-data-to-mssql-server/24922/4 "2020-04-20T08:20:19Z")
Well for starters your SQL is complete nonsense.
Start simple.
1. Use a SQL tool (like microsoft sql server management studio) and get a simple SELECT working
2. Copy there working SQL to an MSSQL node and ensure it works
3. Try building the dynamic where clause using {{{mustache}}} syntax (and read the help info and examples provided in the side bar info panel for the MSSQL-PLUS node)
Edit...
The connection is probably not setup correctly either (that's why you're getting connection errors)
Try this simple query
select getdate() as 'servertime'
⬆ that query should work on any MS SQL server without having to know what databases or tables it has. Use that as a simple test query to ensure your connection settings are correct.
_[View the full topic](https://discourse.nodered.org/t/sending-csv-data-to-mssql-server/24922)._
