# Sending messages to 2 different bots in Telegram
**URL:** <https://discourse.nodered.org/t/sending-messages-to-2-different-bots-in-telegram/94189>\
**Created:** [26 December 2024 18:43 UTC](https://discourse.nodered.org/t/sending-messages-to-2-different-bots-in-telegram/94189 "2024-12-26T18:43:43Z")\
**Post date:** [26 December 2024 19:03 UTC](https://discourse.nodered.org/t/sending-messages-to-2-different-bots-in-telegram/94189/2 "2024-12-26T19:03:32Z")
Hi and welcome to the forum.
Sending to two bots works as i have 2 bots and all works fine.
It is most likely you have not set up 2 separate config nodes, use the + icon to add a separate config for the second bot,.
Please export the flows and paste here, so wee can see if there are any mistakes in your flows. Your botkeys are not exported with the flow if in config nodes, else please obscure the keys and chatids.
[How to import/export a flow](https://nodered.org/docs/user-guide/editor/workspace/import-export)
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/sending-messages-to-2-different-bots-in-telegram/94189)._
