Separating Object/Payload help (Solved) Thank you all
m = msg.payload.CallendarVan_Dusen_Temp_degC__0
return {payload:m}
You could read the docs... https://nodered.org/docs/user-guide/messages
and then there are some great tutorials online about javascript objects and arrays which are worth reading. One that often gets recommended is the w3schools one
If you want to use each data point individually try this flow, makes it easier; each output with its own datapoint
[{"id":"36dcfbda.268ddc","type":"inject","z":"574a0da9.817cfc","name":"","topic":"","payload":"{\"payload\":\"RTD ADC Code: 7627\\n PT100 Resistance: 100.085754 ohms\\n Straight Line Approx. Temp: -17.656250 degC\\n Callendar-Van Dusen Temp (degC > 0): 0.219423 degC\\n high fault threshold: 32767\\n low fault threshold: 0\"}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":280,"y":299,"wires":[["9f329fe8.d40c6"]]},{"id":"b964919f.60ed1","type":"debug","z":"574a0da9.817cfc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":645,"y":161,"wires":[]},{"id":"9f329fe8.d40c6","type":"function","z":"574a0da9.817cfc","name":"","func":"\np = msg.payload.payload\nrow = p.split(/\\r?\\n/)\n\noutput = {}\narr = []\nfor(x=0;x<row.length-1;x++){\n  input = row[x].split(\":\")\n  key = input[0].replace(/[^a-zA-Z0-9 ]/g, '').trim().split(' ').join('_');\n  arr.push({payload:parseFloat(input[1].trim())})\n}\n\nreturn arr;","outputs":7,"noerr":0,"x":420,"y":299,"wires":[["b964919f.60ed1"],["d305f750.c7dcb8"],["8db9b9c0.562d6"],["788f88e3.20bae"],["21b1fe66.047aea"],["a626a122.c22128"],["72889052.71a9d"]]},{"id":"d305f750.c7dcb8","type":"debug","z":"574a0da9.817cfc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":645,"y":207,"wires":[]},{"id":"8db9b9c0.562d6","type":"debug","z":"574a0da9.817cfc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":645,"y":253,"wires":[]},{"id":"788f88e3.20bae","type":"debug","z":"574a0da9.817cfc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":645,"y":299,"wires":[]},{"id":"21b1fe66.047aea","type":"debug","z":"574a0da9.817cfc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":645,"y":345,"wires":[]},{"id":"a626a122.c22128","type":"debug","z":"574a0da9.817cfc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":645,"y":391,"wires":[]},{"id":"72889052.71a9d","type":"debug","z":"574a0da9.817cfc","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":645,"y":437,"wires":[]}]
Works!!!!! whew thank you very much. Now I can make my oven work and not burn dinner!
