# Serial port data at high rate problem with timestamp
**URL:** <https://discourse.nodered.org/t/serial-port-data-at-high-rate-problem-with-timestamp/76499>\
**Created:** [13 March 2023 09:22 UTC](https://discourse.nodered.org/t/serial-port-data-at-high-rate-problem-with-timestamp/76499 "2023-03-13T09:22:11Z")\
**Showing post:** 9
**Author:** ![cameo69](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/cameo69/32/66593_2.png) [@cameo69](https://discourse.nodered.org/u/cameo69)\
**Post date:** [13 March 2023 14:41 UTC](https://discourse.nodered.org/t/serial-port-data-at-high-rate-problem-with-timestamp/76499/9 "2023-03-13T14:41:40Z")
I just quickly ran this and for me it looks good. Probably it is the issue described by @Colin that it is not a realtime environment and if your pi is busy with other things it might become irregular.
Calculated the difference between consecutive timestamps and it looks like this:
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/7/3/73d37abcf9b53ea759948390d1c6cd2ec623d4fb.png)
You can see that no diff = 0 was recorded (blue numbers for the counter nodes).
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/e/7/e70eb25319d1d405cdd3ab698022dc1f51d4e63d.png)
The burst function from here (by @JGKK), slightly modified, but very useful for testing:
> [@Need to design aflow that every 30 min bursts X message with a 30ms interval](https://discourse.nodered.org/t/need-to-design-aflow-that-every-30-min-bursts-x-message-with-a-30ms-interval/30486/8):
> Something like this could do it, of course you would have to adapt it to your times and circumstances as I used way shorter periods to test it and its just a basic example flow. Play with it: [{"id":"6807ce07.123cd","type":"function","z":"35572fe7.e9aef8","name":"burst","func":"var myObj = msg.payload;\nfunction waitSixty () {\n setTimeout(()=\>{\n flow.set(\"timeout\", false);\n },1000);\n}\nfunction repeatThirty (variable) {\n var interval …
demo flow (edited, to clear chart before each run):
[{"id":"afe2a9717e167739","type":"function","z":"b39e02db3febcac7","name":"function 18","func":"let dataArr = msg.payload\nlet timestamp = Date.now()\nlet probeObj = {\n \"timestamp\":timestamp,\n \"P1\":dataArr[0],\n \"P2\":dataArr[1],\n \"P3\":dataArr[2],\n \"P4\":dataArr[3]\n}\nmsg.payload = probeObj\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":430,"y":200,"wires":[["9dcdf4f625098f97","6996523243997805"]]},{"id":"9dcdf4f625098f97","type":"msg-speed","z":"b39e02db3febcac7","name":"","frequency":"sec","interval":1,"estimation":false,"ignore":false,"pauseAtStartup":false,"topicDependent":false,"x":650,"y":200,"wires":[[],["2a0df6e570152edc"]]},{"id":"2a0df6e570152edc","type":"debug","z":"b39e02db3febcac7","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":850,"y":200,"wires":[]},{"id":"88212e65fc6862a8","type":"inject","z":"b39e02db3febcac7","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":220,"y":200,"wires":[["63f795e18b6cfb24","d6c00f0d1c836990"]]},{"id":"8db1084698ed70ff","type":"function","z":"b39e02db3febcac7","name":"burst","func":"var myObj = msg.payload;\nfunction waitSixty () {\n setTimeout(()=>{\n flow.set(\"timeout\", false);\n },10000);\n}\nfunction repeatThirty (variable) {\n var interval = setInterval(()=>{\n node.send({payload:variable});\n var timeout = flow.get(\"timeout\");\n if (!timeout) { clearInterval(interval) }\n },20);\n}\nflow.set(\"timeout\",true);\nwaitSixty();\nrepeatThirty(myObj);\nreturn;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":470,"y":260,"wires":[["4085a98fafaf9a0b","afe2a9717e167739"]]},{"id":"4085a98fafaf9a0b","type":"debug","z":"b39e02db3febcac7","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":630,"y":260,"wires":[]},{"id":"6996523243997805","type":"function","z":"b39e02db3febcac7","name":"calc diff","func":"let ts = msg.payload.timestamp;\nlet lastTS = flow.get('lastTS') || 0;\nflow.set('lastTS', ts);\nlet diff = ts - lastTS;\nif (diff < 10000000000) {\n msg.payload = diff;\n return msg;\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":100,"wires":[["d344787c048eb17f","b54fd4d6c47d83a5","b2c2c61ed6d0c477"]]},{"id":"d344787c048eb17f","type":"ui_chart","z":"b39e02db3febcac7","name":"","group":"8b5cde76.edd58","order":2,"width":0,"height":0,"label":"chart","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":890,"y":100,"wires":[[]]},{"id":"b54fd4d6c47d83a5","type":"debug","z":"b39e02db3febcac7","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":910,"y":60,"wires":[]},{"id":"b2c2c61ed6d0c477","type":"switch","z":"b39e02db3febcac7","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":890,"y":140,"wires":[["b14466bec234beff"],["a0b79bd3e8916ba8"]]},{"id":"b14466bec234beff","type":"counter","z":"b39e02db3febcac7","name":"counter diff = 0","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1080,"y":140,"wires":[]},{"id":"a0b79bd3e8916ba8","type":"counter","z":"b39e02db3febcac7","name":"counter else","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1070,"y":200,"wires":[]},{"id":"63f795e18b6cfb24","type":"delay","z":"b39e02db3febcac7","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":300,"y":260,"wires":[["8db1084698ed70ff"]]},{"id":"d6c00f0d1c836990","type":"change","z":"b39e02db3febcac7","name":"clear chart","rules":[{"t":"set","p":"payload","pt":"msg","to":"[]","tot":"jsonata"},{"t":"set","p":"lastTS","pt":"flow","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":40,"wires":[["d344787c048eb17f"]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"12","collapse":false,"className":""},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","order":4,"disabled":false,"hidden":false}]
_[View the full topic](https://discourse.nodered.org/t/serial-port-data-at-high-rate-problem-with-timestamp/76499)._
