# Series Colors on Pie Chart
**URL:** <https://discourse.nodered.org/t/series-colors-on-pie-chart/2519>\
**Created:** [23 August 2018 17:33 UTC](https://discourse.nodered.org/t/series-colors-on-pie-chart/2519 "2018-08-23T17:33:52Z")\
**Author:** ![davidcgu](https://avatars.discourse-cdn.com/v4/letter/d/e8c25b/32.png) [@davidcgu](https://discourse.nodered.org/u/davidcgu)\
**Post date:** [23 August 2018 17:50 UTC](https://discourse.nodered.org/t/series-colors-on-pie-chart/2519/2 "2018-08-23T17:50:40Z")
The colors are assigned per order or arrival, this means if you have set the order of the screenshoot first message will be on green whatever it is, with or without relation to the real topic or label.
Make a search on the forum as we discussed time ago on another post about this and most probably will help u to understand.
Regards
Look here:
> [@Input order in the Chart node](https://discourse.nodered.org/t/input-order-in-the-chart-node/1213/12):
> Hello Charles You told me you wanted to ensure as soon as the system is started or deployed. In order to do that if you see at start I set all flow variables to off to initiate the sequence on this part: [image] If you wanted this to happen also when you push on delete the data you just need to wire this also from wherever you use to clean the chart to set to "off" again the variables. like this on the example flow I gave you: [image] This will restart the sequence on the same way that ha…
_[View the full topic](https://discourse.nodered.org/t/series-colors-on-pie-chart/2519)._
