# Servo motor Control using a button in a Dashboard
**URL:** <https://discourse.nodered.org/t/servo-motor-control-using-a-button-in-a-dashboard/58805>\
**Tags:** node-red-dashboard, function-node\
**Created:** [22 February 2022 10:00 UTC](https://discourse.nodered.org/t/servo-motor-control-using-a-button-in-a-dashboard/58805 "2022-02-22T10:00:06Z")\
**Post date:** [22 February 2022 10:53 UTC](https://discourse.nodered.org/t/servo-motor-control-using-a-button-in-a-dashboard/58805/2 "2022-02-22T10:53:08Z")
Please don’t double post. This seems to be the same issue you opened in
> [@Parking system dashboard...help](https://discourse.nodered.org/t/parking-system-dashboard-help/58804):
> i m having a final year project and i m struggling with NOde-red the project is parking demo using a RASPBERRY +servo as a gate+apprxomity sensor to check the availability of the LOT i 'll be glad if you can check my node code and fix it ................................................................. [{ "id": "63234a2ef7813cd0", "type": "tab", "label": "Flow 3", "disabled": false, "info": "", "env": [] }, { "id": "bb048f…
I’ll close this thread.
_[View the full topic](https://discourse.nodered.org/t/servo-motor-control-using-a-button-in-a-dashboard/58805)._
