# Set the input signal to high and low for a while of 1 second
**URL:** <https://discourse.nodered.org/t/set-the-input-signal-to-high-and-low-for-a-while-of-1-second/15403>\
**Created:** [11 September 2019 09:43 UTC](https://discourse.nodered.org/t/set-the-input-signal-to-high-and-low-for-a-while-of-1-second/15403 "2019-09-11T09:43:12Z")\
**Showing post:** 12
**Author:** ![bakman2](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/bakman2/32/6207_2.png) [@bakman2](https://discourse.nodered.org/u/bakman2)\
**Post date:** [14 September 2019 10:31 UTC](https://discourse.nodered.org/t/set-the-input-signal-to-high-and-low-for-a-while-of-1-second/15403/12 "2019-09-14T10:31:35Z")
Sorry, incorrect again. (edit your post, don't post new comment)
Read this post
_[View the full topic](https://discourse.nodered.org/t/set-the-input-signal-to-high-and-low-for-a-while-of-1-second/15403)._
