# Sharing flows on the forum just get prettier
**URL:** <https://discourse.nodered.org/t/sharing-flows-on-the-forum-just-get-prettier/97957>\
**Category:** News\
**Created:** [4 July 2025 09:02 UTC](https://discourse.nodered.org/t/sharing-flows-on-the-forum-just-get-prettier/97957 "2025-07-04T09:02:54Z")\
**Showing post:** 27
**Post date:** [6 July 2025 09:07 UTC](https://discourse.nodered.org/t/sharing-flows-on-the-forum-just-get-prettier/97957/27 "2025-07-06T09:07:26Z")
Should the flow position be normalised in some way before visualisation? This is a flow posted in [Neo-pixel LED, heart beat. Help - #2 by Trying\_to\_learn](https://discourse.nodered.org/t/neo-pixel-led-heart-beat-help/97990/2) which is not visible unless you zoom right out and scroll halfway down.
```flows
[{"id":"4d9e128f61b30b9a","type":"trigger","z":"a1911aa3.c45be8","name":"","op1":"40","op2":"0","op1type":"num","op2type":"num","duration":"250","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":750,"y":5330,"wires":[["7a69456b898157aa"],["f2ea8ebf91675d97","7a69456b898157aa"]]},{"id":"7d52e8e1113688cd","type":"trigger","z":"a1911aa3.c45be8","name":"","op1":"20","op2":"0","op1type":"num","op2type":"num","duration":"250","extend":false,"overrideDelay":false,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":970,"y":5380,"wires":[["7a69456b898157aa"],["7a69456b898157aa","ef16a26c16c1e3c2"]]},{"id":"49b7e79d69b3f6ee","type":"inject","z":"a1911aa3.c45be8","name":"Start","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":570,"y":5390,"wires":[["4d9e128f61b30b9a"]]},{"id":"7a69456b898157aa","type":"template","z":"a1911aa3.c45be8","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"rgb,3,0,{{payload}},0","output":"str","x":1130,"y":5330,"wires":[["cd95830a0d79ecd2","e007d147d4be7647"]]},{"id":"f2ea8ebf91675d97","type":"delay","z":"a1911aa3.c45be8","name":"","pauseType":"delay","timeout":"250","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":760,"y":5380,"wires":[["7d52e8e1113688cd"]]},{"id":"22333e36399b9c35","type":"inject","z":"a1911aa3.c45be8","name":"Stop","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"CONTROL","payload":"STOP","payloadType":"str","x":570,"y":5250,"wires":[["1048afc94a871bd0"]]},{"id":"14b8f1d26a67e16e","type":"inject","z":"a1911aa3.c45be8","name":"Go","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"1","topic":"CONTROL","payload":"GO","payloadType":"str","x":570,"y":5290,"wires":[["1048afc94a871bd0"]]},{"id":"1048afc94a871bd0","type":"gate","z":"a1911aa3.c45be8","name":"","controlTopic":"CONTROL","defaultState":"open","openCmd":"GO","closeCmd":"STOP","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":570,"y":5330,"wires":[["4d9e128f61b30b9a"]]},{"id":"ef16a26c16c1e3c2","type":"delay","z":"a1911aa3.c45be8","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1105,"y":5380,"wires":[["1048afc94a871bd0"]],"l":false}]
_[View the full topic](https://discourse.nodered.org/t/sharing-flows-on-the-forum-just-get-prettier/97957)._
