# Shelly integration & MQTT (via MacBook)
**URL:** <https://discourse.nodered.org/t/shelly-integration-mqtt-via-macbook/94672>\
**Tags:** mqtt, shelly\
**Created:** [16 January 2025 07:40 UTC](https://discourse.nodered.org/t/shelly-integration-mqtt-via-macbook/94672 "2025-01-16T07:40:25Z")\
**Post date:** [16 January 2025 08:49 UTC](https://discourse.nodered.org/t/shelly-integration-mqtt-via-macbook/94672/2 "2025-01-16T08:49:17Z")
Seems your not able to connect to the mqtt broker
mqtt2 has some security settings that are enabled by default, or your user and password are incorrect
have a look here for settings for mqtt config file.
> [@Connection to MQTT broker not possible](https://discourse.nodered.org/t/connection-to-mqtt-broker-not-possible/42455/5):
> What version of mosquitto do you have installed ? In your mosquitto.conf file add the lines below because by default the new version 2.0 doesnt allow remote connections by default. [Link](https://mosquitto.org/blog/2020/12/version-2-0-0-released/) allow\_anonymous true listener 1883
_[View the full topic](https://discourse.nodered.org/t/shelly-integration-mqtt-via-macbook/94672)._
