# Shellyplus1 (gen2) Nodered to MQTT
**URL:** <https://discourse.nodered.org/t/shellyplus1-gen2-nodered-to-mqtt/56522>\
**Created:** [12 January 2022 12:24 UTC](https://discourse.nodered.org/t/shellyplus1-gen2-nodered-to-mqtt/56522 "2022-01-12T12:24:21Z")\
**Post date:** [12 January 2022 13:57 UTC](https://discourse.nodered.org/t/shellyplus1-gen2-nodered-to-mqtt/56522/4 "2022-01-12T13:57:07Z")
I do not have any gen2 devices. But what have you tried?
As far as i can make out you send
{"id":123, "src":"user_1", "method":"Switch.Set", "params":{"id":0,"on":true}}
to topic shelly\_id/rpc
> - `id` : number/string, identifier of this request, will be used to match the response frame. **Required**
> - `src` : string, name of the source of the request (you can choose whatever string you like to identify you as the source of the request). **Required**
> - `method` : string, name of the procedure to be called. **Required**
> - `params` : JSON object, parameters that the method takes (if any) **Optional**
_[View the full topic](https://discourse.nodered.org/t/shellyplus1-gen2-nodered-to-mqtt/56522)._
