# Should the node-red install script not handle upgrade of node.js from ARM v6 to ARM v7 instruction set?
**URL:** <https://discourse.nodered.org/t/should-the-node-red-install-script-not-handle-upgrade-of-node-js-from-arm-v6-to-arm-v7-instruction-set/29076>\
**Created:** [27 June 2020 15:37 UTC](https://discourse.nodered.org/t/should-the-node-red-install-script-not-handle-upgrade-of-node-js-from-arm-v6-to-arm-v7-instruction-set/29076 "2020-06-27T15:37:45Z")\
**Post date:** [27 June 2020 15:53 UTC](https://discourse.nodered.org/t/should-the-node-red-install-script-not-handle-upgrade-of-node-js-from-arm-v6-to-arm-v7-instruction-set/29076/2 "2020-06-27T15:53:33Z")
Dave explained the expected behaviour to you in your previous thread: [Can't run node-red](https://discourse.nodered.org/t/cant-run-node-red/2019/30)
If it finds a suitable version of node installed it leaves it alone.
_[View the full topic](https://discourse.nodered.org/t/should-the-node-red-install-script-not-handle-upgrade-of-node-js-from-arm-v6-to-arm-v7-instruction-set/29076)._
