# Shred Payload and make a graph
**URL:** <https://discourse.nodered.org/t/shred-payload-and-make-a-graph/44308>\
**Created:** [17 April 2021 05:04 UTC](https://discourse.nodered.org/t/shred-payload-and-make-a-graph/44308 "2021-04-17T05:04:44Z")\
**Showing post:** 7
**Post date:** [17 April 2021 07:14 UTC](https://discourse.nodered.org/t/shred-payload-and-make-a-graph/44308/7 "2021-04-17T07:14:40Z")
Here is a solution that works for most arrays of objects...
> [@Dynamic series identification from message, send data to Chart](https://discourse.nodered.org/t/dynamic-series-identification-from-message-send-data-to-chart/36682/5):
> So, i am not 100% certain what you are after but if (by the title "dynamic series") you mean sending alternative types of data from a database (i.e. varying fields and varying quantities) then this should get you close. It was a simple adaption of the previous solution I pointed you to, modified to build the series from the field names of the 1st data element in the data passed in. There are 2 injects to simulate two different sets of mySQL data [image] [{"id":"227e8b13.87c804…
With very little changes, you could adapt this.
_[View the full topic](https://discourse.nodered.org/t/shred-payload-and-make-a-graph/44308)._
