# Single Sensor Node (ESP32-S2-Mini or RPi Pico-W)
**URL:** <https://discourse.nodered.org/t/single-sensor-node-esp32-s2-mini-or-rpi-pico-w/84951>\
**Created:** [26 January 2024 17:42 UTC](https://discourse.nodered.org/t/single-sensor-node-esp32-s2-mini-or-rpi-pico-w/84951 "2024-01-26T17:42:42Z")\
**Showing post:** 18
**Post date:** [6 June 2025 10:01 UTC](https://discourse.nodered.org/t/single-sensor-node-esp32-s2-mini-or-rpi-pico-w/84951/18 "2025-06-06T10:01:07Z")
Not sure what you are after?
Can you explain your requirement a bit more and what your objective is?
The ESP32-S3 or S2-Mini devices do not have the resources (memory/storage capability) to run Node-RED. Most people on this Forum (including myself) use the ESP32 devices as remote slaves to sense and/or control things and send/receive information to/from Node-RED using MQTT (where Node-RED is running on a Raspberry Pi, Orange Pi, PC, Laptop).
Here's a link to one of my projects that explains how to use an ESP32 with Node-RED.
> [@Grow Frame AKA Remotely Controlled Station](https://discourse.nodered.org/t/grow-frame-aka-remotely-controlled-station/78870):
> David @dynamicdave and Paul @zenofmud are pleased to announce the release of their Grow Frame AKA Remotely Controlled Station based on an ESP32-S2 Mini flashed with MicroPython. This practical project started out as a simple temperature sensor for a grow frame (a miniature greenhouse designed to cultivate seedlings prior to planting them out in a garden) for my son-in-law. Like a number of our projects it grew and grew (no pun intended) as more functionality was added. The final result is a n…
_[View the full topic](https://discourse.nodered.org/t/single-sensor-node-esp32-s2-mini-or-rpi-pico-w/84951)._
