# Solved: About syntax errors and good debugging practices
**URL:** <https://discourse.nodered.org/t/solved-about-syntax-errors-and-good-debugging-practices/28497>\
**Created:** [17 June 2020 21:17 UTC](https://discourse.nodered.org/t/solved-about-syntax-errors-and-good-debugging-practices/28497 "2020-06-17T21:17:27Z")\
**Showing post:** 3
**Post date:** [17 June 2020 21:45 UTC](https://discourse.nodered.org/t/solved-about-syntax-errors-and-good-debugging-practices/28497/3 "2020-06-17T21:45:05Z")
BTW in your **node-red-log output** you will only see the server side syntax errors, i.e. the syntax errors in your .js file. In the browser console log (like in your screenshot), you will see the client side syntax errors. I.e. the javascript in your .html file.
_[View the full topic](https://discourse.nodered.org/t/solved-about-syntax-errors-and-good-debugging-practices/28497)._
