# SOLVED: Node Red running on a device with 2 IP connections
**URL:** <https://discourse.nodered.org/t/solved-node-red-running-on-a-device-with-2-ip-connections/62740>\
**Created:** [17 May 2022 10:49 UTC](https://discourse.nodered.org/t/solved-node-red-running-on-a-device-with-2-ip-connections/62740 "2022-05-17T10:49:47Z")\
**Showing post:** 6
**Author:** ![kvramji](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/kvramji/32/59005_2.png) [@kvramji](https://discourse.nodered.org/u/kvramji)\
**Post date:** [17 May 2022 13:04 UTC](https://discourse.nodered.org/t/solved-node-red-running-on-a-device-with-2-ip-connections/62740/6 "2022-05-17T13:04:17Z")
I came across this post here
> [@How to change the network interface default node-red chooses](https://discourse.nodered.org/t/how-to-change-the-network-interface-default-node-red-chooses/51015):
> by default node-red starts with the circled network interface (eno1) I would like it to start at (enp1s2)
This one talks about making a static IP against uiHost.
Is it possible for me to have 2 IP's here or am i going completely off track with this train of thought?
_[View the full topic](https://discourse.nodered.org/t/solved-node-red-running-on-a-device-with-2-ip-connections/62740)._
