# Sqlite INSERT command syntax
**URL:** <https://discourse.nodered.org/t/sqlite-insert-command-syntax/21471>\
**Created:** [10 February 2020 01:32 UTC](https://discourse.nodered.org/t/sqlite-insert-command-syntax/21471 "2020-02-10T01:32:28Z")\
**Showing post:** 5
**Post date:** [10 February 2020 16:46 UTC](https://discourse.nodered.org/t/sqlite-insert-command-syntax/21471/5 "2020-02-10T16:46:30Z")
> [@NODE777](#):
> msg = "(UTC, DateTime, hp,lp) values (" + msg.payload + " , " + " datetime " + ", " + hp + ","+ lp + ")";
You have datetime in quotes so it has put that in as a string. You want something like
msg = "(UTC, DateTime, hp,lp) values (" + msg.payload + " , /"" + datetime + "/", " + hp + ","+ lp + ")";
I think it is easier to get right using the syntax
msg = `(UTC, DateTime, hp,lp) values (${msg.payload} , "${datetime}", ${hp}, ${lp})`;
Don't use msg as a variable name unless it is a message, you will get confused at some point if you do that. At least I would.
Also it is good practice not to make a new message when returning, but return the original message after setting up the properties it needs.
_[View the full topic](https://discourse.nodered.org/t/sqlite-insert-command-syntax/21471)._
