# Standalone Flow Viewer Plugin
**URL:** <https://discourse.nodered.org/t/standalone-flow-viewer-plugin/79388>\
**Created:** [24 June 2023 10:58 UTC](https://discourse.nodered.org/t/standalone-flow-viewer-plugin/79388 "2023-06-24T10:58:50Z")\
**Showing post:** 6
**Author:** ![gregorius](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/gregorius/32/73816_2.png) [@gregorius](https://discourse.nodered.org/u/gregorius)\
**Post date:** [25 June 2023 11:05 UTC](https://discourse.nodered.org/t/standalone-flow-viewer-plugin/79388/6 "2023-06-25T11:05:45Z")
ok let us take a typical node definition from flows.json:
        "id": "8bdcf0464a3270ca",
        "type": "change",
        "z": "543929cb2e9c4087",
        "g": "20b77a8b7c7caed7",
        "rules": [
                "t": "set",
                "p": "origfilename",
                "pt": "msg",
                "to": "payload.origfilename",
                "tot": "msg"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 2242,
        "y": 485,
                "1924ae935c6999d9"
I have the type and the name, so I have the text for the node (ok there might be more done in the label function but at [https://flows.nodered.org/](https://flows.nodered.org/) the node names aren't always correct either), I've got a coordinate where the rectangle needs to go - `x` and `y`.
I've got the `z` so that I can group nodes into flows so that I can faithfully render a flow with its nodes.
I have the wires so I can draw the connections between nodes. So I can draw a flow with all its nodes and its connections between nodes.
What I don't have are the colours - true, but is that for a start that important? I understand that the purist would never attempt to do this because it will never be 100% as it is in the editor but that's not what I care about. What I care about is having, instead of a long line of json, an image of the flow, so that at least I can get an approximate idea what the flow does. I can't do that with a json.
A json, for me, is nothing or perhaps at the most, a waste of my time! So anything that gives me a bit of semantic info on what the json is trying to tell me is better than json!
Hence my enthusiasm for doing something here: json is wasting my time: mark json, copy, open node-red instance, go to import flow, paste and view flow. That's the process with a long line of json. If that long line of json were to be rendered in the browser, then I won't have to be doing that.
Of course, probably 80% of the time - to find the issue - one would still have to paste the flow into a running Node-Red instance but there is the 20% when I don't have to copy the json. 20% more time to philosophise about life, the universe and everything.
And of course there will be edge cases but since when has that stopped anyone from itching their scratch?
_[View the full topic](https://discourse.nodered.org/t/standalone-flow-viewer-plugin/79388)._
