# Starting Node-red from Task Manager vs. command line... not the same node-red?
**URL:** <https://discourse.nodered.org/t/starting-node-red-from-task-manager-vs-command-line-not-the-same-node-red/100259>\
**Created:** [27 January 2026 20:00 UTC](https://discourse.nodered.org/t/starting-node-red-from-task-manager-vs-command-line-not-the-same-node-red/100259 "2026-01-27T20:00:16Z")\
**Showing post:** 9
**Author:** ![jbudd](https://avatars.discourse-cdn.com/v4/letter/j/5f8ce5/32.png) [@jbudd](https://discourse.nodered.org/u/jbudd)\
**Post date:** [28 January 2026 19:29 UTC](https://discourse.nodered.org/t/starting-node-red-from-task-manager-vs-command-line-not-the-same-node-red/100259/9 "2026-01-28T19:29:07Z")
Ahem
> [@I would like to learn NODE RED... where do I begin?](https://discourse.nodered.org/t/i-would-like-to-learn-node-red-where-do-i-begin/100173/2):
> A more feasible way to start...
> IMHO the simplest is to use a Debian based Linux machine and the "official" installer script.
Now you start to see the reason for that advice.
_[View the full topic](https://discourse.nodered.org/t/starting-node-red-from-task-manager-vs-command-line-not-the-same-node-red/100259)._
