You can store the incoming data to a database or depending how many points your chart is showing a context variable. You can then restore your chart using the saved data.
If you require more help i suggest you show an example of your incoming data (in text form) and an export of your flow. You can use the debug sidebar too copy data.
code goes here
icon.
