# Suffix for text output
**URL:** <https://discourse.nodered.org/t/suffix-for-text-output/89879>\
**Tags:** dashboard-2\
**Created:** [30 July 2024 12:36 UTC](https://discourse.nodered.org/t/suffix-for-text-output/89879 "2024-07-30T12:36:44Z")\
**Author:** ![smanjunath211](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/smanjunath211/32/95742_2.png) [@smanjunath211](https://discourse.nodered.org/u/smanjunath211)\
**Post date:** [30 July 2024 12:41 UTC](https://discourse.nodered.org/t/suffix-for-text-output/89879/2 "2024-07-30T12:41:43Z")
Edit:
> [@Insert units to a field on dashboard text](https://discourse.nodered.org/t/insert-units-to-a-field-on-dashboard-text/89794/4):
> Hi @AnakinO7 welcome to the forums. In core Node-RED, there is a "template" node (the orange one, not ui-template). It allows you to combine incoming messages and message properties, with text, for example you could write: {{ msg.payload }}°C You could then wire this template to the ui-text node. When passed to the text node, it will render with the °C units.
_[View the full topic](https://discourse.nodered.org/t/suffix-for-text-output/89879)._
