Sumar variables de dos contadores modbus
Hi first welcome.
The flow you posted is corrupt you need to follow these instructions to post code. How to share code or flow json
To access your 2 modbus readings you will need to join the messages, so both readings are in the same message. There is an example in the node-red cookbook Create a single message from separate streams of messages : Node-RED
