# Switch node - MQTT like wildcards for switching
**URL:** <https://discourse.nodered.org/t/switch-node-mqtt-like-wildcards-for-switching/46337>\
**Created:** [27 May 2021 11:54 UTC](https://discourse.nodered.org/t/switch-node-mqtt-like-wildcards-for-switching/46337 "2021-05-27T11:54:50Z")\
**Showing post:** 64
**Post date:** [29 May 2021 13:21 UTC](https://discourse.nodered.org/t/switch-node-mqtt-like-wildcards-for-switching/46337/64 "2021-05-29T13:21:22Z")
> [@knolleary](#):
> Let's not make it sound like a major problem.
Its not & I personally dont think that either ( dont shoot the messenger 😉 )
> [@knolleary](#):
> That doesn't justify in my mind adding them to the switch node that is used for way more than just routing mqtt messages.
I understand your point but to play devils advocate (sorry) - its not really a reason not to add it either. It has a use, aligns with the whole topic concept and is additive (benefits those who would use it - others can ignore it).
> [@knolleary](#):
> I'm not keen on adding such mqtt specific semantics to a non MQTT node where more generalisable solutions can be applied and a wider audience benefits
Am I reading your statement correctly here if i paraphrase that as ...
> **"I'm not keen on adding such mqtt specific semantics to a non MQTT node where a well defined wildcard option could be added for wider audience benefit"**
... or am i mis-reading you Nick?
If I read you right then perhaps we should close this thread off here and start a new discussion on " **wildcard entry for the switch node**" in a new thread?
_(please note I am personally fine with a wildcard solution instead of MQTT filter)_
_[View the full topic](https://discourse.nodered.org/t/switch-node-mqtt-like-wildcards-for-switching/46337)._
