# Switch node to control ui
**URL:** <https://discourse.nodered.org/t/switch-node-to-control-ui/26805>\
**Created:** [17 May 2020 16:03 UTC](https://discourse.nodered.org/t/switch-node-to-control-ui/26805 "2020-05-17T16:03:33Z")\
**Post date:** [17 May 2020 17:52 UTC](https://discourse.nodered.org/t/switch-node-to-control-ui/26805/2 "2020-05-17T17:52:05Z")
Hi, while I'd like to help you, after reading what you wrote I'm confused are you takling about the `switch` node, the `ui-switch` node or both? Fully naming the node makes it easier for someone else to understand.
Please provide your flow (see: [How to share code or flow json](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506) which will help me to understand your need.
_[View the full topic](https://discourse.nodered.org/t/switch-node-to-control-ui/26805)._
