# Switch with indicator
**URL:** <https://discourse.nodered.org/t/switch-with-indicator/14125>\
**Created:** [8 August 2019 07:20 UTC](https://discourse.nodered.org/t/switch-with-indicator/14125 "2019-08-08T07:20:38Z")\
**Showing post:** 8
**Post date:** [9 August 2019 07:31 UTC](https://discourse.nodered.org/t/switch-with-indicator/14125/8 "2019-08-09T07:31:54Z")
Unfortunately the flow is not importable. Please see this post for how to share the flow. You can edit the previous post to insert the backticks.
_[View the full topic](https://discourse.nodered.org/t/switch-with-indicator/14125)._
