# TCP In node read 2 values how to separate into 2 different global variable?
**URL:** <https://discourse.nodered.org/t/tcp-in-node-read-2-values-how-to-separate-into-2-different-global-variable/81755>\
**Created:** [4 October 2023 07:33 UTC](https://discourse.nodered.org/t/tcp-in-node-read-2-values-how-to-separate-into-2-different-global-variable/81755 "2023-10-04T07:33:27Z")\
**Showing post:** 5
**Post date:** [4 October 2023 09:18 UTC](https://discourse.nodered.org/t/tcp-in-node-read-2-values-how-to-separate-into-2-different-global-variable/81755/5 "2023-10-04T09:18:47Z")
Without seeing what you did, it's hard to tell you what you might have done wrong.
Create a small flow demonstrating your problem and export it and attach to a reply. (add a `debug` node to your `TCP` node to capture some data. Then put that in an `inject` node in the sample flow)
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/tcp-in-node-read-2-values-how-to-separate-into-2-different-global-variable/81755)._
