# Telegram Inline keyboard without Command node
**URL:** <https://discourse.nodered.org/t/telegram-inline-keyboard-without-command-node/13275>\
**Created:** [14 July 2019 18:59 UTC](https://discourse.nodered.org/t/telegram-inline-keyboard-without-command-node/13275 "2019-07-14T18:59:04Z")\
**Showing post:** 8
**Author:** ![greengolfer](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/greengolfer/32/28276_2.png) [@greengolfer](https://discourse.nodered.org/u/greengolfer)\
**Post date:** [15 July 2019 09:03 UTC](https://discourse.nodered.org/t/telegram-inline-keyboard-without-command-node/13275/8 "2019-07-15T09:03:56Z")
> [@TotallyInformation](#):
> Do you know how to set up a keyboard anyway? That would be the place to start. Once you've done that, you probably need to send the image in one message and then the keyboard in the next.
I am using the example from the document of telegrambot and once I have sent the /foo I have the keyboard.
I have also used another example [https://discourse.nodered.org/t/turn-flow-on-off-via-iphone/8395/16](https://discourse.nodered.org/t/turn-flow-on-off-via-iphone/8395/16) and both are working fine.
However they all start with a /foo or /start sent by the user.
GV
_[View the full topic](https://discourse.nodered.org/t/telegram-inline-keyboard-without-command-node/13275)._
