# Telegram not connecting: String\[36\] "Error stopping node: Close timed out"
**URL:** <https://discourse.nodered.org/t/telegram-not-connecting-string-36-error-stopping-node-close-timed-out/64076>\
**Created:** [17 June 2022 12:37 UTC](https://discourse.nodered.org/t/telegram-not-connecting-string-36-error-stopping-node-close-timed-out/64076 "2022-06-17T12:37:38Z")\
**Post date:** [18 June 2022 16:21 UTC](https://discourse.nodered.org/t/telegram-not-connecting-string-36-error-stopping-node-close-timed-out/64076/4 "2022-06-18T16:21:25Z")
1 - the link you provided is not your node-red flow it is an html page
2 - most people will not down load a file.
To provide your flow, open NR and go to the hamburger menu. Select `Export`, click on all flows, click the "Copy to clipboard` and add it too a reply.
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/telegram-not-connecting-string-36-error-stopping-node-close-timed-out/64076)._
