You have not stopped the current running node-red, which is why the port is in use. The commands are
node-red-stop
node-red-start
node-red-stop
node-red-start
indeed I did not stop and restart properly, it's done:
---------------AfrikaansAlbanaisAllemandAmhariqueAnglaisArabeArménienAzériBasqueBengaliBiélorusseBirmanBosniaqueBulgareCatalanCebuanoChewaChinois (simplifié)Chinois (traditionnel)CingalaisCoréenCorseCréole haïtienCroateDanoisEspagnolEspérantoEstonienFinnoisFrançaisFrison occidentalGaélique écossaisGalicienGalloisGéorgienGoudjeratiGrecHaoussaHawaïenHébreuHindiHmongHongroisIgboIndonésienIrlandaisIslandaisItalienJaponaisJavanaisKannadaKazakhKhmerKirghizeKurdeLaoLatinLettonLituanienLuxembourgeoisMacédonienMalaisMalayalamMalgacheMaltaisMaoriMarathiMongolNéerlandaisNépalaisNorvégienOurdouOuzbekPachtoPendjabiPersanPolonaisPortugaisRoumainRusseSamoanSerbeShonaSindhiSlovaqueSlovèneSomaliSotho du SudSoundanaisSuédoisSwahiliTadjikTagalogTamoulTchèqueTélougouThaïTurcUkrainienVietnamienXhosaYiddishYorubaZoulouAnglais
ok, I reconfigure the nodes, I found the operation.Mai there is still the problem of the syntax
Hi - what is this node set to return ?
It should be a buffer.
Did you try feeding the wire that goes to debug 1 to a dashboard text node ?
yes, at debug 1 there are no worries,
in fact I start with node-red, and for the intant I make several attempts before embarking on my future project (home automation for my home).
So I wanted to test the storage node, which will be useful later.
and in this case it avoids to interoperate the node openweathermap which is limited to 1 interogation every 10 min.
RIght, nothing suspicious with that function node. Well, the last resort would be you sharing your flow so people in the forum can have a look and try running it to see if the issue is replicated. Just remove the API key from openweathermap if it is a paid subscription.
Thank you for being interested in me.
