In what way? Please show us what your node.warn and errors are showing you. And explain what you expect it is not right.
(I need a new brain.)
Steve, I am so sorry.
This works.
Or it seems to.
const id = env.get("NR_NODE_PATH")
if (msg.delay == undefined) {
let ids = id.split("/");
node.warn("IDS = " + ids);
const errr = `msg.delay not set in message going into ` + ids[1];
node.error(errr,msg);
return;
I get ONLY the subflow's ID in the error message.
I really don't help myself leaving old stuff in while working.
But I would like to get a second set of eyes that I am still not shooting myself in the foot.
And this will work on 3.0.x NR.
It looks fine to me. I'd probably tweak it to be...
const ids = id.split("/")
node.warn({error_path: ids})
const errr = `msg.delay not set in message going into ${ids[1]}`
node.error(errr, msg)
return
return msg
Functionally no different, just a bit more concise IMO.
THANK YOU
I am not having a good time just now....
(Not wanting to sound ungrateful)
The only thing that would be even better is if that value ids[1] could be put in error.source.id
But that may be pushing the friendship with NR (and maybe you).
Me asking all these difficult questions - and for an older version of NR too.
I think you could simply add a property to the msg
msg.source = ids[1]
return
return msg
Oh, ok.
I wasn't sure if those parts were editable by the user.
They were set by the system determined by the originating node.
(The path is not quite right, but I get what you mean. Thanks)
Interesting.
Your code (well, that extra line) added and put in.
The node.warn is kind of handy.
Brown box/line is the node.warn.
So I press the inject node.
You see the 3 parts of the ids after being split.
But somehow the error.source.id gets corrupted with that extra stuff (see red underline)
Not a big deal.
As the id is also shown just above (sorry I didn't point to it) that is enough.
I was being overly lazy to try and make a field like most other nodes that I can/could copy to paste in the search field.
Thoughts?
But please, don't if you have other stuff to do.
This is a long way from where I was originally.
You must use === for this to work, otherwise null will also pass the test, and possibly other falsy values. Try this code to see it
let n = null
if (n == undefined) {
node.warn("null == undefined")
In fact it is better to use typeof
if (typeof msg.delay === "undefined") {
Ah!
Ok, yeah.
Shall try now.
(Hang on.)
No sorry, same.
And the id is still corrupted.
Ah, as I said, I am getting the needed, I just need to be careful with cutting only the right part and pasting it.
(As it will be all over the place and if one isn't getting a delay value....)
But - of course - now I've fixed all those problems.
This is me trying to be a good person so if ever I give it to someone else it has a bit more bullet proofing for them.
I wasn't suggesting that it would fix your problem, I was just pointing out that you test for undefined was not safe, it would give undefined for cases that were in fact defined, such as null.
Sorry.
Got hung up on the problem.
But thanks.
This is another thing I need to keep in mind when writing stuff.
It is better to try and fall forward and learn the tricks to better coding.
But I fear I am still very near the bottom (maybe a couple of rungs up) of the ladder.
I had maybe call it solved here.
Again: Thanks for the help.
