# Time Picker in ui\_form node sends wrong time in output payload
**URL:** <https://discourse.nodered.org/t/time-picker-in-ui-form-node-sends-wrong-time-in-output-payload/71296>\
**Tags:** home-assistant\
**Created:** [26 November 2022 18:08 UTC](https://discourse.nodered.org/t/time-picker-in-ui-form-node-sends-wrong-time-in-output-payload/71296 "2022-11-26T18:08:25Z")\
**Showing post:** 54
**Post date:** [28 November 2022 14:51 UTC](https://discourse.nodered.org/t/time-picker-in-ui-form-node-sends-wrong-time-in-output-payload/71296/54 "2022-11-28T14:51:43Z")
> [@E1cid](#):
> > [@Colin](#):
> > Well $toMillis() is wrong as far as I can see.
> Is it? or is it handling the year round UK DST in 1970 correctly?
If I put, in a Change node, Set msg.payload To JSONata `$toMillis("1970-01-01T16:01:00.000Z")` I get 57660000, which agrees with Date.getTime(). Where did you see $toMillis() give 61260000 for that timestamp?
_[View the full topic](https://discourse.nodered.org/t/time-picker-in-ui-form-node-sends-wrong-time-in-output-payload/71296)._
