Moment is very good at what it does, but as Julian has pointed out - it's a true heavyweight!
node-red-contrib-moment code size = 7MB
node-red-contrib-simpletime code size = 40KB
node-red-dashboard code size = 3.7MB
node-red-contrib-ramp-thermostat code size = 72KB
Thank you, Nick.
I ended up with simple function:
var now = new Date().toLocaleString("en-GB");
return {payload: now};
Paul-Reed:
I've never been known as a lightweight that's for sure!
So I read this and couldn't seem to get it to populate this correctly.
msg.payload = {state:true,timestamp:1579362774639}
So the inbound message is a boolean 0 or 1 value without the "state:" for a ui_statetrail node.
I keep losing either the boolean or the timestamp.
Any suggestion here?
try msg.payload = {"state":true,"timestamp":1579362774639}
Tried that I need the timestamp to be now() and the state as the inbound boolean value
Or, as I mentioned, if you need the timestamp in seconds rather than ms:
msg.payload = {
"state": msg.payload,
"timestamp": ( Date.now() / 1000 )
Use $now('[D01].[M01].[Y0001] [H01]:[m01]:[s01]', '+0200'). Where +0200 is an offset of your time zone. This will result in something like this:
"06.07.2020 21:07:53"
Taken from here: Date/Time functions Ā· JSONata
