# Trouble getting the results of a looped subflow to write into an array
**URL:** <https://discourse.nodered.org/t/trouble-getting-the-results-of-a-looped-subflow-to-write-into-an-array/95134>\
**Created:** [5 February 2025 05:02 UTC](https://discourse.nodered.org/t/trouble-getting-the-results-of-a-looped-subflow-to-write-into-an-array/95134 "2025-02-05T05:02:26Z")\
**Showing post:** 3
**Post date:** [5 February 2025 08:03 UTC](https://discourse.nodered.org/t/trouble-getting-the-results-of-a-looped-subflow-to-write-into-an-array/95134/3 "2025-02-05T08:03:43Z")
I assume that you have an `inject` node connecting to the function node and that `inject` node is sending a timestamp as msg.payload. If you change the `inject` node to send a string, you will see that spring replacing the time stamps.
When you have an issue it is wise to provide a simple flow showing the issue.
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/trouble-getting-the-results-of-a-looped-subflow-to-write-into-an-array/95134)._
