# Trouble Registering Custom Node
**URL:** <https://discourse.nodered.org/t/trouble-registering-custom-node/8237>\
**Created:** [21 February 2019 17:51 UTC](https://discourse.nodered.org/t/trouble-registering-custom-node/8237 "2019-02-21T17:51:27Z")\
**Showing post:** 5
**Post date:** [21 February 2019 22:02 UTC](https://discourse.nodered.org/t/trouble-registering-custom-node/8237/5 "2019-02-21T22:02:06Z")
Hi @tcontrada
as a side note, when sharing code of any sort, it helps to format it properly - this post explains how/why: [How to share code or flow json](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506)
The `.node-red/nodes` directory is used to load local nodes that are not packaged as a module - so the package.json is ignored and it will load any .js/.html file pair it can find.
Are there any error messages in the log when you start Node-RED related to your node?
_[View the full topic](https://discourse.nodered.org/t/trouble-registering-custom-node/8237)._
