# Troubleshooting an error on IBM cloud
**URL:** <https://discourse.nodered.org/t/troubleshooting-an-error-on-ibm-cloud/16877>\
**Created:** [19 October 2019 07:46 UTC](https://discourse.nodered.org/t/troubleshooting-an-error-on-ibm-cloud/16877 "2019-10-19T07:46:14Z")\
**Showing post:** 9
**Post date:** [22 October 2019 20:46 UTC](https://discourse.nodered.org/t/troubleshooting-an-error-on-ibm-cloud/16877/9 "2019-10-22T20:46:50Z")
> [@knolleary](#):
> Have you added `node-red-dashboard` through the palette manager
Yes I had installed it via the pallette manager.
> [@knolleary](#):
> whenever the app is restaged
Ah that explains a couple of things ...
This evening I had published a new version of my heatmap node on NPM, and updated it via the palette manager on IBM cloud. But then I got following error afterwards:
![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/2X/7/7d778c660038ecb9df83d745824d657770651438.png)
But as mentioned above, I use IBM cloud now for the first time (only to assist 1 single user). Have been reading a bit about it, but don't want to waste too much time on it ...
So I tried at last my own workaround to restart Node-RED _ **hard** _ way:
- I logged on to the SSH panel
- I did `ps -ef` to get the PID of the running node-red process
- The I executed a `kill` of that PID
- And immediately afterwards I had a Node-RED instance with my new heatmap code up and running
I assume your _ **soft** _ way is much better 😇
Will try to do it via the package.json file...
_[View the full topic](https://discourse.nodered.org/t/troubleshooting-an-error-on-ibm-cloud/16877)._
