# Trying to get Alexa to read out a temperature
**URL:** https://discourse.nodered.org/t/trying-to-get-alexa-to-read-out-a-temperature/56974
**Category:** General
**Created:** [20 January 2022 14:56 UTC](https://discourse.nodered.org/t/trying-to-get-alexa-to-read-out-a-temperature/56974 "2022-01-20T14:56:30Z")
**Showing post:** 41
### Author: ![dynamicdave](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/dynamicdave/32/96_2.png) [@dynamicdave](https://discourse.nodered.org/u/dynamicdave)
#### Post date: [28 January 2022 08:33 UTC](https://discourse.nodered.org/t/trying-to-get-alexa-to-read-out-a-temperature/56974/41 "2022-01-28T08:33:25Z")
Hi Des,
Just had a few spare minutes to extend your flow to include a personalised message for your Alexa device.
Hope this works for you? Please let me know how you get on with it.
 ![Screen Shot 01-28-22 at 08.47 AM](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/9/e/9e833a9ab33e79efce3d374cfb2477fbbf321610.gif)
[{"id":"fdedac607f20a384","type":"tab","label":"Flow 2","disabled":false,"info":"","env":[]},{"id":"d9cef3911a340322","type":"alexa-remote-event","z":"fdedac607f20a384","name":"","account":"f5c58b4876dbd6b3","event":"ws-device-activity","x":170,"y":280,"wires":[["d9dd3578e3584bfa"]]},{"id":"c596f864e8ddf6d2","type":"mqtt in","z":"fdedac607f20a384","name":"Room temp","topic":"tele/garage/SENSOR","qos":"2","datatype":"json","broker":"22f544be.780a3c","nl":false,"rap":false,"inputs":0,"x":150,"y":120,"wires":[["23949a4c8a9421e3","48d81bc5f11542c5"]]},{"id":"d9dd3578e3584bfa","type":"switch","z":"fdedac607f20a384","name":"Filter","property":"payload.alexaResponse","propertyType":"msg","rules":[{"t":"cont","v":"temperature is","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":370,"y":280,"wires":[["fa4ad52f77a3a689","138e818ddc1d6dd3"]]},{"id":"64da3017d499a99a","type":"alexa-remote-routine","z":"fdedac607f20a384","name":"","account":"f5c58b4876dbd6b3","routineNode":{"type":"speak","payload":{"type":"announcement","text":{"type":"msg","value":"payload"},"devices":["G090LF1173660KCR"]}},"x":980,"y":280,"wires":[[]]},{"id":"138e818ddc1d6dd3","type":"function","z":"fdedac607f20a384","name":"Read variable(s) and format message for Alexa","func":"// Get the flow variable(s) to be used in the message\nvar temperature = flow.get(\"temperature\") || 0;\n\n// Convert them to a string\ntemperature = temperature.toString();\n\n// Start building the message\nvar message = \"<break time='0.25s'/> Hi Des here's your report on your tasmota device<break time='0.5s'/>\";\n\nmessage += \"temperature of the unit is <break time='0.1s'/>\"+temperature+ \"degrees sea <break time='0.25s'/>\";\n\n// This the footer for the message\nmessage += \"<break time='0.75s'/> that's the end of the report\";\n\nmsg.payload = message;\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":660,"y":280,"wires":[["64da3017d499a99a","92381d845bdd0256"]]},{"id":"23949a4c8a9421e3","type":"debug","z":"fdedac607f20a384","name":"6","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":130,"y":80,"wires":[]},{"id":"fa4ad52f77a3a689","type":"debug","z":"fdedac607f20a384","name":"7","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":370,"y":340,"wires":[]},{"id":"92381d845bdd0256","type":"debug","z":"fdedac607f20a384","name":"11","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":530,"y":340,"wires":[]},{"id":"48d81bc5f11542c5","type":"function","z":"fdedac607f20a384","name":"","func":"// Save the reading(s) in a flow variable\n\nflow.set(\"temperature\",msg.payload.SI7021.Temperature);\n\nreturn null;\n","outputs":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":340,"y":120,"wires":[]},{"id":"dd868057aab722b3","type":"function","z":"fdedac607f20a384","name":"Test setting temperature to 21","func":"flow.set(\"temperature\",msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":410,"y":180,"wires":[[]]},{"id":"fcb0cd6fa3135761","type":"inject","z":"fdedac607f20a384","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"21","payloadType":"num","x":150,"y":180,"wires":[["dd868057aab722b3"]]},{"id":"0335514a2b601c42","type":"inject","z":"fdedac607f20a384","name":"Click to test the text sent to Alexa","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":230,"y":240,"wires":[["138e818ddc1d6dd3"]]},{"id":"f5c58b4876dbd6b3","type":"alexa-remote-account","name":"opt","authMethod":"proxy","proxyOwnIp":"192.168.1.147","proxyPort":"3456","cookieFile":"authFile","refreshInterval":"3","alexaServiceHost":"alexa.amazon.co.uk","amazonPage":"amazon.co.uk","acceptLanguage":"en-UK","userAgent":"","useWsMqtt":"on","autoInit":"on"},{"id":"22f544be.780a3c","type":"mqtt-broker","name":"Mosquitto","broker":"192.168.1.147","port":"1883","clientid":"","usetls":false,"compatmode":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
_[View the full topic](https://discourse.nodered.org/t/trying-to-get-alexa-to-read-out-a-temperature/56974)._
