# Trying to retrieve info from a website problems, I'm just a rookie
**URL:** <https://discourse.nodered.org/t/trying-to-retrieve-info-from-a-website-problems-im-just-a-rookie/5092>\
**Created:** [21 November 2018 13:45 UTC](https://discourse.nodered.org/t/trying-to-retrieve-info-from-a-website-problems-im-just-a-rookie/5092 "2018-11-21T13:45:29Z")\
**Showing post:** 15
**Post date:** [21 November 2018 19:37 UTC](https://discourse.nodered.org/t/trying-to-retrieve-info-from-a-website-problems-im-just-a-rookie/5092/15 "2018-11-21T19:37:18Z")
please read this post and then edit your flow
_[View the full topic](https://discourse.nodered.org/t/trying-to-retrieve-info-from-a-website-problems-im-just-a-rookie/5092)._
