UI dashboard editing
To export the flow, select the nodes and select Export from the menu, or Ctrl+E, and Copy to Clipboard. Then paste it here. When pasting use the </> button at the top of the forum entry window and paste it between the lines with three backticks.
Edit: Are you using the latest version of node-red-dashboard? Check in Palette Manager. Also what version of node-red are you using (at the bottom of the dropdown menu).
as already requested by me and others, please share the flow so that we can see what is going on.
  1. Press Ctrl+A to select all nodes (unless you want to select manually what nodes to export)
  2. then Ctrl+E to bring up the export dialogue.
  3. click on copy to clipboard
  4. paste the copied content here after clicking </> symbol.
flows.json (69.9 KB)
This is the my flow's json format file.
as expected, you have created a multiple groups and are expecting to have a divider in between, which is difficult since the dashboard dynamically adjusts the position of groups according to width available
see below gif for what i mean.
to achieve what you are expecting, you need to have all 'widgets' which you want to flock together in one group. and make a dummy text node with 1 unit height and group width wide to have a 'line' between two sections.
n
Without creating multiple groups, I can't give the headlines for each column. That's why I created a many groups.
I dont think thats a correct assumption, are you not interested in HTML table solution ?
this is how a single group would look like
[{"id":"06237266fbf51a6f","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":14,"width":18,"height":1,"name":"Title-2","label":"Title-2","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":620,"y":1430,"wires":[]},{"id":"de21be7110d0c1f6","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":2,"width":3,"height":1,"name":"Heading-1","label":"Heading-1","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Times New Roman,Times,serif","fontSize":"18","color":"#ffea00","x":630,"y":1230,"wires":[]},{"id":"9f07339407729201","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":8,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1262,"wires":[]},{"id":"d80af4e28ac3f47b","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":21,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1230,"wires":[]},{"id":"5378c62e4270bf63","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":1,"width":18,"height":1,"name":"Title-1","label":"TITLE-1","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":620,"y":1190,"wires":[]},{"id":"7b6e10a89be6ef36","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":15,"width":3,"height":1,"name":"Heading-11","label":"Heading-11","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#0c50ed","x":640,"y":1475.454545454545,"wires":[]},{"id":"e86607cd23effa6a","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":9,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1326,"wires":[]},{"id":"0fa181934bc167d2","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":22,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1294,"wires":[]},{"id":"0472b60f85ecb4c1","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":10,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1358,"wires":[]},{"id":"9bbb88a7100cebc9","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":23,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1390,"wires":[]},{"id":"cb60fc7cba877243","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":11,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1502,"wires":[]},{"id":"56a14e6cb251ee70","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":24,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1470,"wires":[]},{"id":"4d1db0a72858f176","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":12,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1598,"wires":[]},{"id":"7d83e8b93873655e","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":25,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1566,"wires":[]},{"id":"c45d2525a6238b70","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":13,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1630,"wires":[]},{"id":"5c4317a95b3b6e98","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":26,"width":3,"height":1,"name":"voltage_R6_a","label":"voltage_R6_a","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#ffffff","x":840,"y":1534,"wires":[]},{"id":"50729f217f66b7c3","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":4,"width":3,"height":1,"name":"Heading-3","label":"Heading-3","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Times New Roman,Times,serif","fontSize":"18","color":"#ffea00","x":630,"y":1294,"wires":[]},{"id":"0455a67904e25473","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":5,"width":3,"height":1,"name":"Heading-4","label":"Heading-4","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Times New Roman,Times,serif","fontSize":"18","color":"#ffea00","x":630,"y":1326,"wires":[]},{"id":"f25e0d7244ac1aa1","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":7,"width":3,"height":1,"name":"Heading-6","label":"Heading-6","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Times New Roman,Times,serif","fontSize":"18","color":"#ffea00","x":630,"y":1390,"wires":[]},{"id":"61a9d08ad35b1dd5","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":6,"width":3,"height":1,"name":"Heading-5","label":"Heading-5","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Times New Roman,Times,serif","fontSize":"18","color":"#ffea00","x":630,"y":1358,"wires":[]},{"id":"e3a943f9f87f5c45","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":3,"width":3,"height":1,"name":"Heading-2","label":"Heading-2","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Times New Roman,Times,serif","fontSize":"18","color":"#ffea00","x":630,"y":1262,"wires":[]},{"id":"35da0597e1d64125","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":16,"width":3,"height":1,"name":"Heading-21","label":"Heading-21","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#0c50ed","x":640,"y":1508.363636363636,"wires":[]},{"id":"9e3f18e655f22439","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":17,"width":3,"height":1,"name":"Heading-31","label":"Heading-31","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#0c50ed","x":640,"y":1541.272727272727,"wires":[]},{"id":"cda9a189cab29f4a","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":18,"width":3,"height":1,"name":"Heading-41","label":"Heading-41","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#0c50ed","x":640,"y":1574.181818181818,"wires":[]},{"id":"da35259dc1018ecd","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":19,"width":3,"height":1,"name":"Heading-51","label":"Heading-51","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#0c50ed","x":640,"y":1607.090909090909,"wires":[]},{"id":"4a5c866abb52363c","type":"ui_text","z":"76a1f2fc1e5fa676","group":"e2a7d25b55ba1726","order":20,"width":3,"height":1,"name":"Heading-61","label":"Heading-61","format":"{{msg.payload}}","layout":"col-center","className":"","style":true,"font":"Palatino Linotype,Palatino,Book Antiqua,serif","fontSize":"18","color":"#0c50ed","x":640,"y":1640,"wires":[]},{"id":"e2a7d25b55ba1726","type":"ui_group","name":"New_Group1","tab":"968dca3170df8616","order":1,"disp":false,"width":"18","collapse":false,"className":""},{"id":"968dca3170df8616","type":"ui_tab","name":"New","icon":"dashboard","order":5,"disabled":false,"hidden":false}]
@smanjunath211 I think this one good compare to my flow. Let me try with your shared flow. Thank you for clearing this issue.
