# UI-SVG animation using SVG parameters as variables
**URL:** <https://discourse.nodered.org/t/ui-svg-animation-using-svg-parameters-as-variables/66710>\
**Created:** [20 August 2022 20:44 UTC](https://discourse.nodered.org/t/ui-svg-animation-using-svg-parameters-as-variables/66710 "2022-08-20T20:44:58Z")\
**Post date:** [20 August 2022 21:11 UTC](https://discourse.nodered.org/t/ui-svg-animation-using-svg-parameters-as-variables/66710/2 "2022-08-20T21:11:35Z")
Hi @thalesmaoa,
I can imagine that fixed center coordinates might indeed change.
We had another question about rotating around the center. See [here](https://discourse.nodered.org/t/svg-node-rotate-an-element/62603/3).
Perhaps you can get ideas from that discussion.
Bart
_[View the full topic](https://discourse.nodered.org/t/ui-svg-animation-using-svg-parameters-as-variables/66710)._
