# ui\_Switch not working on iOS devices
**URL:** <https://discourse.nodered.org/t/ui-switch-not-working-on-ios-devices/43730>\
**Created:** [5 April 2021 22:06 UTC](https://discourse.nodered.org/t/ui-switch-not-working-on-ios-devices/43730 "2021-04-05T22:06:54Z")\
**Post date:** [6 April 2021 09:37 UTC](https://discourse.nodered.org/t/ui-switch-not-working-on-ios-devices/43730/2 "2021-04-06T09:37:27Z")
> [@wimphot](#):
> I have Node-RED -vers 10.23.1
That is probably the nodejs version. Look at the bottom of the node-red editor menu dropdown to see the node-red version. More importantly check you are using the latest version of node-red-dashboard which you can see from Manage Palette in the menu.
For the future see this post for how to share flows here so they are easily importable by others - [How to share code or flow json](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506)
_[View the full topic](https://discourse.nodered.org/t/ui-switch-not-working-on-ios-devices/43730)._
