# Ui-table supports ui\_control
**URL:** <https://discourse.nodered.org/t/ui-table-supports-ui-control/18870>\
**Created:** [6 December 2019 16:05 UTC](https://discourse.nodered.org/t/ui-table-supports-ui-control/18870 "2019-12-06T16:05:57Z")\
**Showing post:** 20
**Post date:** [7 August 2020 16:56 UTC](https://discourse.nodered.org/t/ui-table-supports-ui-control/18870/20 "2020-08-07T16:56:34Z")
Hi ...
did some tests and yes there is a little bit of a problem with the `.getCell('id')` if the id is hidden or was never visible. Could not find the cause, perhaps a bug of the tabulator version we use. But the `.getIndex()` from the row component should work.
function(cell){
    this.send({
        ui_control:{callback:'cellEdited'},
        payload:cell.getValue(),
        oldValue:cell.getOldValue(),
        field:cell.getColumn().getField(),
and it is more versatile than specifying the index field name.
I updated the example flow too:
[{"id":"2e6a6379.742abc","type":"ui_table","z":"c4712650.59b5e8","group":"ff9fdb9a.7da098","name":"testTable","order":2,"width":"8","height":5,"columns":[{"field":"rowNumber","title":"Row Number 1","width":"","align":"left","formatter":"rownum","formatterParams":{"target":"_blank"}},{"field":"textValue","title":"Text","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}},{"field":"numberValue","title":"Number","width":"","align":"left","formatter":"plaintext","formatterParams":{"target":"_blank"}}],"outputs":1,"cts":true,"x":808,"y":357,"wires":[["1c377ea0.5801e1","c0a33274.5dbeb"]]},{"id":"16664cef.5b26b3","type":"function","z":"c4712650.59b5e8","name":"table paramter","func":"msg.ui_control = {tabulator:{}};\n\n//workaround that buttos can`t deliver empty strings\nif (msg.payload.hasOwnProperty('payload')) {\n msg.payload=msg.payload.payload;\n}\n\nmsg.ui_control.tabulator[msg.topic]=msg.payload;\ndelete msg.topic;\nmsg.payload=null;\nreturn msg;","outputs":1,"noerr":0,"x":590,"y":646,"wires":[["2e6a6379.742abc","b8d75d24.6cbed"]]},{"id":"b8d75d24.6cbed","type":"debug","z":"c4712650.59b5e8","name":"table input","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":818,"y":646,"wires":[]},{"id":"1c377ea0.5801e1","type":"debug","z":"c4712650.59b5e8","name":"table output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":971,"y":357,"wires":[]},{"id":"b15c31a9.af37c","type":"ui_switch","z":"c4712650.59b5e8","name":"selectable","label":"selectable","tooltip":"","group":"ff9fdb9a.7da098","order":3,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"selectable","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":230,"y":442,"wires":[["16664cef.5b26b3"]]},{"id":"75207e8d.c54d4","type":"ui_switch","z":"c4712650.59b5e8","name":"movableColumns","label":"movableColumns","tooltip":"","group":"ff9fdb9a.7da098","order":5,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"movableColumns","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":260,"y":493,"wires":[["16664cef.5b26b3"]]},{"id":"c585e7a1.dfc648","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":6,"width":"4","height":"1","passthru":false,"label":"Format Numbers > 100","tooltip":"using a rowFormatter callback function","color":"","bgcolor":"","icon":"","payload":"function(row){ if(row.getData().numberValue>100){ row.getElement().style.backgroundColor = \"#A6A6DF\"; } },","payloadType":"str","topic":"rowFormatter","x":280,"y":629,"wires":[["16664cef.5b26b3"]]},{"id":"f178c6fe.710ef8","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":1,"width":0,"height":0,"passthru":false,"label":"Fill demo data","tooltip":"","color":"","bgcolor":"","icon":"","payload":"[{\"textValue\":\"Line #1\",\"numberValue\":123.12},{\"textValue\":\"Line #2\",\"numberValue\":100},{\"textValue\":\"Line #3\",\"numberValue\":50}]","payloadType":"json","topic":"rowFormatter","x":250,"y":357,"wires":[["2e6a6379.742abc"]]},{"id":"2403f929.df4006","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":8,"width":"4","height":"1","passthru":false,"label":"inject Tooltips callback","tooltip":"cell.getColumn().getField() + \" - \" + cell.getValue();","color":"","bgcolor":"","icon":"","payload":"function(cell){return cell.getColumn().getField() + \" - \" + cell.getValue(); },","payloadType":"str","topic":"tooltips","x":270,"y":731,"wires":[["16664cef.5b26b3"]]},{"id":"f6c68c45.58003","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":9,"width":"4","height":"1","passthru":false,"label":"clear Tooltips callback","tooltip":"empty string is not possible! so use a single space","color":"","bgcolor":"","icon":"","payload":"{\"payload\":\"\"}","payloadType":"json","topic":"tooltips","x":270,"y":765,"wires":[["16664cef.5b26b3"]]},{"id":"d2b29dda.60a5a","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":10,"width":"4","height":"1","passthru":false,"label":"reformat Number column","tooltip":"inject additional paramters to numberValue column","color":"","bgcolor":"","icon":"","payload":"[{\"field\":\"numberValue\",\"formatterParams\":{\"min\":0,\"max\":200,\"legend\":\"function (value) { if (value<100) return \\\"<span style='color:#FF0000;'>\\\"+value+\\\"</span>\\\"; else return \\\"<span style='color:#000000;'>\\\"+value+\\\"</span>\\\"; }\",\"legendAlign\":\"center\"},\"formatter\":\"progress\",\"topCalc\":\"function(values, data, calcParams){ var total = 0; var calc = 0; var count = 0; data.forEach(value => { total+=Number(value.numberValue); count++; }); if (count>0) calc=(total/count).toFixed(2); return `${calc} (avg)`; }\",\"headerTooltip\":\"avarage\"}]","payloadType":"json","topic":"columns","x":280,"y":833,"wires":[["16664cef.5b26b3"]]},{"id":"7b6490b3.cd9c7","type":"function","z":"c4712650.59b5e8","name":"callback function(s)","func":"// how to use the editor to write callback functions\n// DO NOT wire this into your flow!\n// copy / paste \"function( ... }\" into the correct calback parameter\n// use the \"debugger\" statement to debug your callback inside your browser\n\nvar topCalc = function(values, data, calcParams){\n var total = 0;\n var calc = 0;\n var count = 0;\n data.forEach(value => {\n total+=Number(value.numberValue);\n count++;\n });\n if (count>0) calc=(total/count).toFixed(2);\n return `${calc} (avg)`;\n}\n\nvar legend = function (value) {\n if (value<100) return \"<span style='color:#FF0000;'>\"+value+\"</span>\";\n else return \"<span style='color:#000000;'>\"+value+\"</span>\"; \n}\n\nvar cellEdited = function(cell){\n this.send({\n ui_control:{callback:'cellEdited'}, \n payload:cell.getValue(),\n oldValue:cell.getOldValue(),\n field:cell.getColumn().getField(),\n id:cell.getRow().getIndex()\n }); \n}","outputs":1,"noerr":0,"x":600,"y":765,"wires":[[]]},{"id":"91506d4b.4956a","type":"comment","z":"c4712650.59b5e8","name":"Intentionally not wired into the flow!","info":"use the editor to write callback functions\n\nDO NOT wire this into your flow!\n\ncopy / paste `function( ... }` into the correct calback parameter\nuse the `debugger` statement to debug your callback inside your browser\n","x":650,"y":731,"wires":[]},{"id":"732afcea.f728f4","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":11,"width":"4","height":"1","passthru":false,"label":"reset Number column","tooltip":"inject additional paramters to numberValue column","color":"","bgcolor":"","icon":"","payload":"[{\"field\":\"numberValue\",\"formatter\":\"plaintext\",\"topCalc\":\"\",\"headerTooltip\":\"\"}]","payloadType":"json","topic":"columns","x":270,"y":867,"wires":[["16664cef.5b26b3"]]},{"id":"89cca7ea.7fc998","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":12,"width":"4","height":"1","passthru":false,"label":"add/show id column","tooltip":"add a new column","color":"","bgcolor":"","icon":"","payload":"[{\"field\":\"id\",\"title\":\"id\",\"visible\":true,\"formatter\":\"plaintext\"}]","payloadType":"json","topic":"columns","x":270,"y":935,"wires":[["16664cef.5b26b3"]]},{"id":"32a3c4ad.1b85fc","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":13,"width":"4","height":"1","passthru":false,"label":"hide id column","tooltip":"hide id column (it is not possible to delete a existing column definition)","color":"","bgcolor":"","icon":"","payload":"[{\"field\":\"id\",\"title\":\"id\",\"visible\":false,\"formatter\":\"plaintext\"}]","payloadType":"json","topic":"columns","x":250,"y":969,"wires":[["16664cef.5b26b3"]]},{"id":"25247f4b.cc7ec","type":"inject","z":"c4712650.59b5e8","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":84,"y":493,"wires":[["75207e8d.c54d4","bd3fd382.a2aa9"]]},{"id":"18ed8d27.bf00a3","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":7,"width":"4","height":"1","passthru":false,"label":"reset Numbers > 100","tooltip":"using a rowFormatter callback function","color":"","bgcolor":"","icon":"","payload":"{\"payload\":\"\"}","payloadType":"json","topic":"rowFormatter","x":270,"y":663,"wires":[["16664cef.5b26b3"]]},{"id":"bd3fd382.a2aa9","type":"ui_switch","z":"c4712650.59b5e8","name":"headerVisible","label":"headerVisible","tooltip":"","group":"ff9fdb9a.7da098","order":4,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"headerVisible","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":250,"y":544,"wires":[["16664cef.5b26b3"]]},{"id":"ce8d3904.be1b08","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":15,"width":"4","height":"1","passthru":false,"label":"inject cellEdited callback","tooltip":"","color":"","bgcolor":"","icon":"","payload":"function(cell){ this.send({ ui_control:{callback:'cellEdited'}, payload:cell.getValue(), oldValue:cell.getOldValue(), field:cell.getColumn().getField(), id:cell.getRow().getIndex() }); }","payloadType":"str","topic":"cellEdited","x":280,"y":1071,"wires":[["16664cef.5b26b3"]]},{"id":"f7b8bb20.5217f8","type":"ui_button","z":"c4712650.59b5e8","name":"","group":"ff9fdb9a.7da098","order":14,"width":"4","height":"1","passthru":false,"label":"enable cell edit (Text)","tooltip":"set \"editor\" to \"input\"","color":"","bgcolor":"","icon":"","payload":"[{\"field\":\"textValue\",\"title\":\"Text\",\"editor\":\"input\",\"formatter\":\"plaintext\"}]","payloadType":"json","topic":"columns","x":270,"y":1037,"wires":[["16664cef.5b26b3"]]},{"id":"c0a33274.5dbeb","type":"ui_text","z":"c4712650.59b5e8","group":"ff9fdb9a.7da098","order":16,"width":0,"height":0,"name":"","label":"table Output","format":"{{msg.payload}} id:{{msg.id}}","layout":"row-spread","x":971,"y":391,"wires":[]},{"id":"ff9fdb9a.7da098","type":"ui_group","z":"","name":"TEST","tab":"7dcc246f.ee661c","order":1,"disp":false,"width":"8","collapse":false},{"id":"7dcc246f.ee661c","type":"ui_tab","z":"","name":"TEST","icon":"dashboard","order":12,"disabled":false,"hidden":false}]
_[View the full topic](https://discourse.nodered.org/t/ui-table-supports-ui-control/18870)._
