# UI\_template button - not refreshing dashboard
**URL:** https://discourse.nodered.org/t/ui-template-button-not-refreshing-dashboard/87556
**Category:** Dashboard
**Tags:** function-node, ui-template
**Created:** [27 April 2024 21:25 UTC](https://discourse.nodered.org/t/ui-template-button-not-refreshing-dashboard/87556 "2024-04-27T21:25:08Z")
**Showing post:** 3
### Author: ![E1cid](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/e1cid/32/77971_2.png) [@E1cid](https://discourse.nodered.org/u/E1cid)
#### Post date: [29 April 2024 10:52 UTC](https://discourse.nodered.org/t/ui-template-button-not-refreshing-dashboard/87556/3 "2024-04-29T10:52:50Z")
Hi and welcome.
Have you tried unchecking all but `refresh on reload` at bottom of config.
If this does not fix issue can you export a minimal example of this flow. [How to import/export a flow](https://nodered.org/docs/user-guide/editor/workspace/import-export)
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/ui-template-button-not-refreshing-dashboard/87556)._
