Fixed it by adding the missing span:
[{"id":"449863c1.3b7fec","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"1","order":2,"width":1,"height":1,"format":"<div>\n <md-button class=\"md-button remote-button bigger\"\n data-ontext=\"Btn4\\nOn\"\n data-offtext=\"Btn4\\nOff\"\n data-onbgcolour='#ff0000'\n data-offbgcolour='#660000'\n data-buttontype=\"toggle\"\n data-topic=\"1\"\n data-payload=\"1\">1\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":130,"y":140,"wires":[[]]},{"id":"700f1600.04891c","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"2","order":3,"width":1,"height":1,"format":"<div>\n <md-button class=\"md-button remote-button bigger\"\n data-ontext=\"Btn4\\nOn\"\n data-offtext=\"Btn4\\nOff\"\n data-onbgcolour='#ff0000'\n data-offbgcolour='#660000'\n data-buttontype=\"toggle\"\n data-topic=\"2\"\n data-payload=\"2\">2\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":250,"y":140,"wires":[[]]},{"id":"4c6394f2.9d8d9c","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"3","order":4,"width":1,"height":1,"format":"<div>\n <md-button class=\"md-button remote-button bigger\"\n data-ontext=\"Btn4\\nOn\"\n data-offtext=\"Btn4\\nOff\"\n data-onbgcolour='#ff0000'\n data-offbgcolour='#660000'\n data-buttontype=\"toggle\"\n data-topic=\"3\"\n data-payload=\"3\">3\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":370,"y":140,"wires":[[]]},{"id":"98688ec.eae177","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"4","order":5,"width":1,"height":1,"format":"<!--\n V1\n ==\n data-icon0=\"fa fa-circle-o\"\n data-icon1=\"fa fa-check-circle-o\"\n//-->\n<div>\n <md-button class=\"md-button remote-button small\"\n data-ontext=\"On\"\n data-offtext=\"Off\"\n data-onbgcolour='#0000ff'\n data-offbgcolour='#000066'\n data-buttontype='radio'\n data-radiogroup='group1'\n data-icon0=\"fa fa-circle-o\"\n data-icon1=\"fa fa-check-circle-o\"\n data-topic=\"4\"\n data-payload=\"4\">\n <i class=\"fa fa-circle-o\"></i>\n <span>off</span>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":130,"y":180,"wires":[[]]},{"id":"b6b4ee71.45c86","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"5","order":6,"width":1,"height":1,"format":"<div>\n <md-button class=\"md-button remote-button small\"\n data-ontext=\"On\"\n data-offtext=\"Off\"\n data-onbgcolour='#0000ff'\n data-offbgcolour='#000066'\n data-buttontype='radio'\n data-radiogroup='group1'\n data-topic=\"5\"\n data-icon0=\"fa fa-circle-o\"\n data-icon1=\"fa fa-check-circle-o\"\n data-payload=\"5\">\n <i class=\"fa fa-circle-o\"></i>\n <span>off</span>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":250,"y":180,"wires":[[]]},{"id":"6fa8e5a1.c6102c","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"6","order":7,"width":1,"height":1,"format":"<div>\n <md-button class=\"md-button remote-button small\"\n data-ontext=\"On\"\n data-offtext=\"Off\"\n data-onbgcolour='#0000ff'\n data-offbgcolour='#000066'\n data-buttontype='radio'\n data-radiogroup='group1'\n data-topic=\"6\"\n data-icon0=\"fa fa-circle-o\"\n data-icon1=\"fa fa-check-circle-o\"\n data-payload=\"6\">\n <i class=\"fa fa-circle-o\"></i>\n <span>off</span>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":370,"y":180,"wires":[[]]},{"id":"b045c8d3.031958","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"script for all buttons with class remote-button","order":14,"width":"1","height":"1","format":"<div>\n<!--diliberately emtpy - only need the script below -->\n</div>\n\n<script>\n\n(function($scope) {\n//debugger\n\n //cause a small delay while things load \n //ideally this would be an init event or on all parts of document loaded\n //(may not be necessary!)\n setTimeout(function() {\n //debugger\n $scope.init();\n },100);\n \n \n //SETTINGS...\n var BUTTON_CLASS = \".remote-button\";\n var SEND_0_FOR_CLEARED_RADIO_BUTTONS = true;\n var SEND_ONLY_STATE_CHANGES_RADIO_BUTTONS = true;\n \n \n /** \n * Initialise all buttons with class BUTTON_CLASS\n */\n $scope.init = function () {\n //debugger\n console.log(\"$scope.init called. Adding event handlers to all buttons with class '\" + BUTTON_CLASS + \"'.\");\n var clickButtons = $(BUTTON_CLASS) \n clickButtons.click(function(e){\n \n var btn = $(this)\n var type = btn.data(\"buttontype\");//get the button type from attribute data-buttontype=\"xxxxx\"\n var topic = btn.data(\"topic\");//get the topic from attribute data-topic=\"xxxxx\"\n var payload = btn.data(\"payload\");//get the payload from attribute data-payload=\"xxxxx\"\nvar group = btn.data(\"radiogroup\") || null;\nvar state = btn.data(\"state\") || 0;//get the last state payload from attribute data-state=\"n\"\nvar ck = {\"class\": BUTTON_CLASS, \"new type\": type, \"topic\":topic,\"payload\":payload, \"group\": group, \"state\": state, \"event\": \"click\"};\nconsole.log(\"click():\",ck);\n //debugger\n if(type == \"radio\"){\n setRadioButton(btn, true);\n } else if(type == \"toggle\"){\n var state = btn.data(\"state\") || 0;//get the last state payload from attribute data-state=\"n\"\n var newPayload = state == 1 ? 0 : 1;\n setButtonState(btn,newPayload)\n var tm = {\"type\": type, \"topic\":topic,\"payload\":newPayload, \"event\": \"click\"}\n console.log(\"Sending msg for clicked toggle button\", tm)\n $scope.send(tm)\n } else {\n var sm = {\"type\": type, \"topic\":topic,\"payload\":payload, \"event\": \"click\"}\n console.log(\"Sending msg for clicked button\", tm)\n $scope.send(sm)\n }\n });\n \n };\n\n //watch for node-red msgs\n $scope.$watch('msg', function(msg) {\n //debugger\n if(!msg){ //if no msg \n console.log(\"$scope.$watch('msg', ...) - msg is empty\");\n return;\n }\n if(!msg.topic){ //if no topic set found\n console.log(\"msg.topic is empty - cannot match this to any button\")\n return; //stop processing!\n }\n\n var buttonSelector = BUTTON_CLASS + \"[data-topic='\" + msg.topic + \"']\" \n var $btn = $(buttonSelector);//get the button\n \n if(!$btn.length){ //if no button found\n console.log(buttonSelector + \" not found - cannot set state\")\n return; //stop processing!\n }\n \n if($btn.length > 1){ //if MORE than one button found\n console.log(buttonSelector + \" found more than 1 button - is this intended? Do you have the same data-topic set on multiple buttons?\")\n }\n \n //see if this is a command - if so, process the command\n if(typeof msg.payload === \"object\" && msg.payload.command){\n processCommand($btn, msg.payload)\n return;\n } \n \n if($btn.data(\"buttontype\") === \"radio\"){\n setRadioButton($btn, false);\n }\n \n if($btn.data(\"buttontype\") === \"toggle\"){\n if(msg.payload == \"1\"){\n setButtonState($btn, 1);\n } else if(msg.payload == \"0\"){\n setButtonState($btn, 0);\n } else {\n console.log(\"Invalid toggle value in msg.payload, cannot set \" + buttonSelector + \". Ensure msg.payload is either 0 or 1\") \n }\n }\n\n }); \n \n /** \n * helper function to set the correct icon & update the \"data-payload\" memory \n */\n function setButtonState($btn, state){\n console.log(\"setButtonState\", $btn[0], state);\n var oldState = $btn.data(\"state\");\n var btntxt = \"\";\n var btnbgc = \"#333333\";\n $btn.data(\"state\", state);//set data-payload to new state value (used as a memory)\n \n //determine the opposite state\n var oppositeState;\n if(state == \"1\" || state === 1){\n state = 1; //normalise to a number\n oppositeState = 0;\n btntxt = $btn.data(\"ontext\");\n btnbgc = $btn.data(\"onbgcolour\");\n } else {\n state = 0; //normalise to a number\n oppositeState = 1;\n btntxt = $btn.data(\"offtext\");\n btnbgc = $btn.data(\"offbgcolour\");\n }\n var $icon = $btn.find(\"i\"); //get the <i> element\n var $span = $btn.find(\"span\"); //get the <span> element\n if(!$icon.length){\n $icon = $btn.find(\"span\"); //get the <span> element instead!\n }\n if(!$icon.length){\n console.log(\"<i> or <span> not found inside button - cant toggle the icon!\")\n return oldState;//exit this function - nothing to toggle!\n }\n \n //get the old icon and new icon names\n var oldIcon = $btn.data(\"icon\" + oppositeState); //get icon1 or icon2 depending on oppositeState\n var newIcon = $btn.data(\"icon\" + state); //get icon1 or icon2 depending on newPayload\n \n //if we have newIcon and an actual DOM element ($icon) - update it...\n if(newIcon && $icon.length){\n if(newIcon.includes(\"fa-\")){ \n $icon.removeClass(oldIcon).addClass(newIcon); // fontawesome\n } else { \n $icon.text(newIcon); // MDI\n }\n $icon.css({\"background-color\": btnbgc});\n $span.css({\"background-color\": btnbgc});\n $span.text(btntxt);\n }\n return oldState;\n }\n\n\n /** \n * helper function \n */\n function setRadioButton($btn, sendMsgs){\n var topic = $btn.data(\"topic\");//get the topic from attribute data-topic=\"xxxxx\"\n var group = $btn.data(\"radiogroup\");\n var groupBtns = $(\"[data-radiogroup='\"+group+\"']\");\n var m = null;\n for(var i = 0; i < groupBtns.length; i++) {\n var oldState;\n var rb = $(groupBtns[i]);\n if(!rb || !rb.length) continue;\n var t = rb.data(\"topic\");\n if(t == topic) continue;//skip clicked button\n oldState = setButtonState(rb,0);\n if(sendMsgs && SEND_0_FOR_CLEARED_RADIO_BUTTONS) {\n if(SEND_ONLY_STATE_CHANGES_RADIO_BUTTONS && oldState == 0) continue;\n m = {\"type\": \"radio\", \"topic\":t,\"payload\":0, \"event\": \"click\"};\n console.log(\"Sending 0 payload for other radio button in group\", m)\n $scope.send(m);\n }\n }\n if(sendMsgs) {\n// var p = $btn.data(\"payload\");//get the payload from attribute data-payload=\"xxxxx\"\n// var m = {\"type\": \"radio\", \"topic\":topic, \"payload\": p, \"event\": \"click\"};\n var m = {\"type\": \"radio\", \"topic\":topic, \"payload\": 1, \"event\": \"click\"};\n console.log(\"Sending msg for radio button\", m)\n $scope.send(m);\n }\n setButtonState($btn,1);//set state of this button\n setTimeout(function(){\n setButtonState($btn,1);//set state of this button \n },200) \n\n }\n \n function processCommand($btn, payload){\n //first check payload is correct format...\n if(!payload || !payload.command || !payload.value){\n console.log(\"Cannot process command. Expected a payload object with .command and .value. \")\n }\n var cmd = payload.command.trim();\n switch(cmd){\n case \"addClass\":\n $btn.addClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n break;\n case \"toggleClass\":\n $btn.toggleClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n break;\n case \"removeClass\":\n $btn.removeClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n break;\n default:\n console.log(\"command '\" + payload.command + \"' is not supported\")\n }\n } \n \n /** \n * helper function to determine a value is REALLY a number \n */\n function isNumeric(n){\n if(n === \"\") return false;\n if(n === true || n === false) return false;\n return !isNaN(parseFloat(n)) && isFinite(n);\n }\n \n\n})(scope);\n</script>","storeOutMessages":false,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":250,"y":340,"wires":[["ac92a2e7.532df"]]},{"id":"ac92a2e7.532df","type":"debug","z":"cb2d7de9.28bbe","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":530,"y":340,"wires":[]},{"id":"7f2122c8.6d6c3c","type":"inject","z":"cb2d7de9.28bbe","name":"choose radio btn 4","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"4","payload":"4","payloadType":"num","x":150,"y":500,"wires":[["b045c8d3.031958"]]},{"id":"97dbd289.389b","type":"inject","z":"cb2d7de9.28bbe","name":"toggleClass disabled, on 5","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"5","payload":"{\"command\":\"toggleClass\",\"value\":\"disabled\"}","payloadType":"json","x":170,"y":440,"wires":[["b045c8d3.031958"]]},{"id":"75fbec6e.793664","type":"inject","z":"cb2d7de9.28bbe","name":"choose radio btn 5","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"5","payload":"5","payloadType":"num","x":150,"y":540,"wires":[["b045c8d3.031958"]]},{"id":"5295fbe8.20ecf4","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"7","order":8,"width":1,"height":1,"format":"<div>\n <md-button class=\"md-button remote-button small\"\n data-ontext=\"On\"\n data-offtext=\"Off\"\n data-onbgcolour='#00ff00'\n data-offbgcolour='#006600'\n data-buttontype='radio'\n data-radiogroup='group2'\n data-topic=\"7\"\n data-icon0=\"fa fa-circle-o\"\n data-icon1=\"fa fa-check-circle-o\"\n data-payload=\"7\">\n <i class=\"fa fa-circle-o\"></i>\n <span>off</span>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":130,"y":220,"wires":[[]]},{"id":"8118294d.6b4298","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"8","order":9,"width":1,"height":1,"format":"<div>\n <md-button class=\"md-button remote-button small\"\n data-ontext=\"nOn\"\n data-offtext=\"Off\"\n data-onbgcolour='#00ff00'\n data-offbgcolour='#006600'\n data-buttontype='radio'\n data-radiogroup='group2'\n data-topic=\"8\"\n data-icon0=\"fa fa-circle-o\"\n data-icon1=\"fa fa-check-circle-o\"\n data-payload=\"8\">\n <i class=\"fa fa-circle-o\"></i>\n <span>off</span>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":250,"y":220,"wires":[[]]},{"id":"4f76813a.a6fe6","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"9","order":10,"width":1,"height":1,"format":"<div>\n <md-button class=\"md-button remote-button small\"\n data-ontext=\"On\"\n data-offtext=\"Off\"\n data-onbgcolour='#00ff00'\n data-offbgcolour='#006600'\n data-buttontype='radio'\n data-radiogroup='group2'\n data-topic=\"9\"\n data-icon0=\"fa fa-circle-o\"\n data-icon1=\"fa fa-check-circle-o\"\n data-payload=\"9\">\n <i class=\"fa fa-circle-o\"></i>\n <span>off</span>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":370,"y":220,"wires":[[]]},{"id":"c9b79c0f.e8ef1","type":"comment","z":"cb2d7de9.28bbe","name":"radiogroup1","info":"","x":490,"y":180,"wires":[]},{"id":"71c9ddee.9f3d34","type":"comment","z":"cb2d7de9.28bbe","name":"radiogroup2","info":"","x":490,"y":220,"wires":[]},{"id":"fb6d5cde.77948","type":"inject","z":"cb2d7de9.28bbe","name":"toggleClass blinking, on 5","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"5","payload":"{\"command\":\"toggleClass\",\"value\":\"blinking\"}","payloadType":"json","x":470,"y":440,"wires":[["b045c8d3.031958"]]},{"id":"772502cd.dad3ac","type":"ui_template","z":"cb2d7de9.28bbe","group":"49c9cca6.e7da04","name":"CSS only ","order":1,"width":0,"height":0,"format":"<style>\n :root {\n --dashboard-unit-width: 48px;\n --dashboard-unit-height: 48px;\n --remote-button-background: black;\n --remote-button-foreground: #cccccc;\n }\n .nr-dashboard-template {\n padding: 0px;\n }\n \n .remote-button:not([disabled]):hover{\n background-color: #232323 !important;\n }\n\n .remote-button.red:not([disabled]) {\n background-color: #cc0000;\n color: var(--remote-button-foreground);\n }\n .remote-button.green:not([disabled]) {\n background-color: #00bb00;\n color: var(--remote-button-foreground);\n }\n \n\n /* This is the normal button definition */\n .remote-button{\n background-color: var(--remote-button-background) !important;\n color: var(--remote-button-foreground);\n height: var(--dashboard-unit-height);\n width: 100%;\n border-radius: 10px;\n font-size:1.0em;\n font-weight:normal;\n margin: 0;\n min-height: 36px;\n min-width: unset;\n line-height: unset;\n }\n /* This is a sub-set which is invoked by */\n /* <md-button class=\"md-button remote-button bigger\"> */\n /* note the (space) \"bigger\" at the end. */\n .remote-button.bigger{\n font-weight:bold;\n font-size:1.5em;\n }\n /* This is for buttons with a lot of text. `font-size:0.7em` */\n /* makes the font 70% normal size */\n .remote-button.small{\n font-size:0.7em;\n }\n /* This is for buttons with just icons, to upsize the size */\n /* of the icon with the line: */\n /* <i class=\"fa fa-fw fa-plus remote-icon\"> in the other node */\n .remote-icon{\n font-size:2.0em;\n }\n /* This is the same as the other one, but it makes the icon smaller */\n .remote-iconS{\n font-size:0.5em;\n }\n .remote-button.red{\n background-color: #cc0000 !important;\n }\n .remote-button.green{\n background-color: #00bb00 !important;\n }\n .remote-button.blue{\n background-color: #0000dd !important;\n }\n .remote-button.red.disabled {\n background-color: #440000 !important;\n color: #666666 !important;\n }\n .remote-button.green.disabled {\n background-color: #004400 !important;\n color: #666666 !important;\n }\n .remote-button.blue.disabled {\n background-color: #000066 !important;\n color: #666666 !important;\n }\n .remote-button.disabled {\n cursor: not-allowed;\n pointer-events: none;\n background-color: #222222;\n color: #666666;\n }\n\n .remote-button.blinking {\n animation: blink-animation 1s steps(5, start) infinite;\n animation-timing-function: ease;\n -webkit-animation: blink-animation 1s steps(5, start) infinite;\n }\n @keyframes blink-animation {\n to { visibility: hidden; }\n }\n @-webkit-keyframes blink-animation {\n to { visibility: hidden; }\n }\n.remote-button.warning {\n color: red;\n}\n\n.remote-button.animated .remote-button.warning {\n -webkit-animation: pulse 1s infinite;\n animation: pulse 1s infinite;\n}\n\n@-webkit-keyframes pulse {\n 0% {\n opacity: 0.2\n }\n\n 35% {\n opacity: 1.0\n }\n\n 100% {\n opacity: 0.2\n }\n}\n\n@keyframes pulse {\n 0% {\n opacity: 0.2\n }\n\n 35% {\n opacity: 1.0\n }\n\n 100% {\n opacity: 0.2\n }\n}\n\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"global","x":140,"y":300,"wires":[[]]},{"id":"a01fe5a2.5ff8f8","type":"inject","z":"cb2d7de9.28bbe","name":"toggleClass red, on 5","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"5","payload":"{\"command\":\"toggleClass\",\"value\":\"red\"}","payloadType":"json","x":460,"y":480,"wires":[["b045c8d3.031958"]]},{"id":"19c84e72.c23fe2","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"mute","order":12,"width":1,"height":1,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"mute\"\n data-icon0=\"volume_off\"\n data-icon1=\"volume_mute\"\n aria-label=\"volume mute\"\n >\n <i class=\"material-icons md-48\">volume_mute</i>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":250,"y":260,"wires":[[]],"info":" class=\"material-icons\"> volume_off"},{"id":"c1c9b13b.49d93","type":"ui_template","z":"cb2d7de9.28bbe","group":"50a1d6b5.ce2c88","name":"0","order":2,"width":"3","height":1,"format":"<div>\n <md-button class=\"md-button remote-button bigger\"\n data-ontext=\"Btn4\\nOn\"\n data-offtext=\"Btn4\\nOff\"\n data-onbgcolour='#aa00aa'\n data-offbgcolour='#660066'\n data-topic=\"0\"\n data-payload=\"0\">0\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":130,"y":100,"wires":[[]]},{"id":"50a1d6b5.ce2c88","type":"ui_group","z":"","name":"HOME","tab":"6ff5405c.a8e6","order":1,"disp":true,"width":3,"collapse":false},{"id":"49c9cca6.e7da04","type":"ui_group","z":"","name":"Full_Remote2","tab":"58443ae1.3adab4","order":3,"disp":false,"width":"3","collapse":false},{"id":"6ff5405c.a8e6","type":"ui_tab","z":"","name":"TEST","icon":"dashboard","order":3,"disabled":false,"hidden":false},{"id":"58443ae1.3adab4","type":"ui_tab","z":"","name":"HDMI_TV_control","icon":"dashboard","order":7,"disabled":false,"hidden":false}]
and:
$icon.css({"background-color": btnbgc});
$span.text(btntxt);
Work OK but how do I change the button background color.
I tried:
$span.css({"background-color": btnbgc});
$span.text(btntxt);
It looks like this:
