Here is a more complete example.
Note the following...
buttonNamein the HTML is bound toscope.buttonNamein the scriptscope.funcis set as a function & so is avaiable to call inng-clickasfunc(...)- When a
msgarrives from node-red side, we can adjustscope.buttonNameand it is immediately reflected in the dashboard button text
<md-button id="{{'my_button_'+$id}}" ng-click="func($event)">{{buttonName}}</md-button>
<script>
(function(scope) {
scope.buttonName = "clare";
scope.func = function($event) {
console.log("button clicked (you will see me in the console)");
scope.send({payload:scope.buttonName});
//watch for incoming messages
scope.$watch('msg', function(msg) {
console.log("msg received", msg);
if (msg && msg.topic == "set-button-text") {
// Set button text when msg.topic == "set-button-text"
scope.buttonName = msg.payload;
})(scope);
</script>
Demo...
Flow (use CTRL+I to import)...
[{"id":"7e5679cc6a223311","type":"ui_template","z":"c2233fc1d8cc5c3b","group":"81dd3718.b97888","name":"","order":1,"width":0,"height":0,"format":"<md-button id=\"{{'my_button_'+$id}}\" ng-click=\"func($event)\">{{buttonName}}</md-button>\n\n<script>\n\n\n (function(scope) {\n scope.buttonName = \"clare\";\n\n scope.func = function($event) {\n console.log(\"button clicked (you will see me in the console)\");\n scope.send({payload:scope.buttonName});\n }\n\n //watch for incoming messages\n scope.$watch('msg', function(msg) {\n console.log(\"msg received\", msg);\n if (msg && msg.topic == \"set-button-text\") {\n // Set button text when msg.topic == \"set-button-text\"\n scope.buttonName = msg.payload;\n }\n });\n })(scope);\n</script>","storeOutMessages":true,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":2780,"y":120,"wires":[["8ac528363579be05"]]},{"id":"e66177ee39c19a5b","type":"inject","z":"c2233fc1d8cc5c3b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"set-button-text","payload":"sarah","payloadType":"str","x":2590,"y":120,"wires":[["7e5679cc6a223311"]]},{"id":"8ac528363579be05","type":"debug","z":"c2233fc1d8cc5c3b","name":"","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":2770,"y":180,"wires":[]},{"id":"a5d7db11fcf7c2d2","type":"inject","z":"c2233fc1d8cc5c3b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"set-button-text","payload":"clare","payloadType":"str","x":2590,"y":80,"wires":[["7e5679cc6a223311"]]},{"id":"81dd3718.b97888","type":"ui_group","name":"Home","tab":"4e11db25.239e94","order":1,"disp":true,"width":"8","collapse":true,"className":""},{"id":"4e11db25.239e94","type":"ui_tab","name":"Buttons","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
