# Ultrasonic sensor object detection
**URL:** <https://discourse.nodered.org/t/ultrasonic-sensor-object-detection/24007>\
**Created:** [1 April 2020 06:08 UTC](https://discourse.nodered.org/t/ultrasonic-sensor-object-detection/24007 "2020-04-01T06:08:16Z")\
**Showing post:** 9
**Post date:** [1 April 2020 10:58 UTC](https://discourse.nodered.org/t/ultrasonic-sensor-object-detection/24007/9 "2020-04-01T10:58:27Z")
try the node-red-contrib-pisrf node
> [@HC-SR04 Ultrasonic Sensor - rpi-srf - status not available](https://discourse.nodered.org/t/hc-sr04-ultrasonic-sensor-rpi-srf-status-not-available/21955/6):
> The node works for me (trig connected to pin10 - echo to pin 8, gnd to pin6 , vcc to pin 1) There are a a few things to check Have you got a newer 3.3V compatible version? If using an old 5V version - you need to use some resistors to reduce the echo signal voltage
_[View the full topic](https://discourse.nodered.org/t/ultrasonic-sensor-object-detection/24007)._
