Unable to display image from base64
This is the best I can do.
Solution requires node-red-contrib-image-tools
Issues...
  1. Start and end of image data assumed to be byte[1] ~ last byte
  2. Size of image assumed to be Wx95 Hx96
  3. Colour calculation guessed (and no where near the mapping in you VB application)
Without Gaussian blur, it looks like this...
Flow...
[{"id":"d6e8b32e.3f4f4","type":"base64","z":"e78eac1c.8b9cf","name":"","action":"","property":"payload","x":420,"y":580,"wires":[["c1909507.69cc88","2c48238b.d5aeac"]]},{"id":"c1909507.69cc88","type":"debug","z":"e78eac1c.8b9cf","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":610,"y":580,"wires":[]},{"id":"6a57790f.262ad8","type":"jimp-image","z":"e78eac1c.8b9cf","name":"blank img","data":"{\"w\":95,\"h\":96,\"background\":0}","dataType":"json","ret":"img","parameter1":"imgBatchOps","parameter1Type":"msg","parameter2":"","parameter2Type":"msg","parameter3":"","parameter3Type":"msg","parameter4":"","parameter4Type":"msg","parameter5":"","parameter5Type":"msg","parameter6":"","parameter6Type":"msg","parameter7":"","parameter7Type":"msg","parameter8":"","parameter8Type":"msg","parameterCount":0,"jimpFunction":"none","selectedJimpFunction":{"name":"none","fn":"none","description":"Just loads the image.","parameters":[]},"x":500,"y":640,"wires":[["330ed265.8dc41e"]]},{"id":"2c48238b.d5aeac","type":"change","z":"e78eac1c.8b9cf","name":"","rules":[{"t":"set","p":"imgData","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":310,"y":640,"wires":[["6a57790f.262ad8"]]},{"id":"330ed265.8dc41e","type":"function","z":"e78eac1c.8b9cf","name":"draw pixels","func":"const LINE_WIDTH = 2;\nconst LINE_COLOR = 0xED143DFF;\nconst startIndex = 1;\n\nvar jimpImage = msg.payload;\nlet imgW = jimpImage.bitmap.width;\nlet imgH = jimpImage.bitmap.height;\nvar imgData = msg.imgData\n\n\n//create clamping functions to avoid printing outside of image\nlet clampX = (val) => clamp(val,0,imgW);\nlet clampY = (val) => clamp(val,0,imgH);\n\n//add imgBatchOps to msg for drawing text in next node \nmsg.imgBatchOps = [];\n\nvar buf = Buffer.from([0,0,0,255]);\nfunction rgbaToInt(red,green,blue,alpha){\n    \n    var r = red & 0xFF;\n    var g = green & 0xFF;\n    var b = blue & 0xFF;\n    var a = alpha & 0xFF;\n    \n    buf[0] = r;\n    buf[1] = g;\n    buf[2] = b;\n    return buf.readUInt32BE(0);\n    //return (r << 16) + (g << 8) + (b);\n    //return (r << 24 >>> 0) | (g << 16) | (b << 8) | (a);\n}\n\nvar dmin = 255, dmax = 0;\nfor(let x = 0; x < jimpImage.bitmap.width; x++){\n    for(let y = 0; y < jimpImage.bitmap.height; y++){\n        let index = x * y;\n        let d = imgData[index + startIndex]\n        if(d < dmin) dmin = d;\n        if(d > dmax) dmax = d;\n        let c = rgbaToInt(d,d,0,255)\n        jimpImage.setPixelColor(c, x, y) ;\n    }\n}\nmsg.dmin = dmin;\nmsg.dmax = dmax;\n\n\n\n// function drawBox(img, box) {\n//     //get box ccords\n//     let x = box.bbox[0];\n//     let y = box.bbox[1];\n//     let w = box.bbox[2];\n//     let h = box.bbox[3];\n    \n//     scanHLine(img, x, y+h-14, w, 14, 0xfa758e22); //draw box for text\n//     scanRectangle(img, x, y, w, h, LINE_WIDTH, LINE_COLOR);//draw outer rect\n    \n//     //built batch operations for next image node to draw text\n//     msg.imgBatchOps.push(  \n//         {\n//             \"name\": \"print\",\n//             \"parameters\": [\n//                 \"FONT_SANS_10_BLACK\",\n//                 clampX(x+2),\n//                 clampY(y+h-16),\n//                 box.class\n//             ]\n//         }\n        \n//     );  \n// }\n\n// function drawBoxes(img, detections) {\n//     detections.forEach(element => drawBox(img, element))\n// }\n\n\n// function makeColorIterator(color) {\n//   return function (x, y, offset) {\n//     this.bitmap.data.writeUInt32BE(color, offset, true);\n//   }\n// }\n\n// function scanRectangle(image,x,y,w,h,linePX,color){\n//     let iterator = makeColorIterator(color);\n   \n//     let xw, yh;\n//     x = clampX(x-(linePX/2));\n//     y = clampY(y-(linePX/2));\n//     w = clampX(w);\n//     h = clampY(h);\n//     xw = clampX(x+w);\n//     yh = clampY(y+h);\n\n    \n//     if(y+linePX <= imgH){\n//         image.scan(x, y, w, linePX,  iterator);// scan linePX height line - TOP\n//     }\n//     if(yh+linePX <= imgH){\n//         image.scan(x, yh, w, linePX, iterator);// scan linePX height line - BOTTOM\n//     }\n//     if(x+linePX <= imgW){\n//         image.scan(x, y, linePX, h,  iterator);// scan linePX width line - LEFT\n//     }\n//     if(xw+linePX <= imgW){\n//         image.scan(xw, y, linePX, h, iterator);// scan linePX width line - RIGHT\n//     }\n    \n// }\n\n\n// function scanHLine(image,x,y,length,linePX,color){\n//     let iterator = makeColorIterator(color);\n//     x = clampX(x);\n//     y = clampY(y);\n//     length = clampX(length);\n//     if(y+linePX <= imgH){\n//         image.scan(x, y, length, linePX,  iterator);// \n//     }\n// }\n\n// function scanVLine(image,x,y,height,linePX,color){\n//     let iterator = makeColorIterator(color);\n//     x = clampX(x);\n//     y = clampY(y);\n//     height = clampY(y+height);\n//     if(x+linePX <= imgW){\n//         image.scan(x, y, linePX, height,  iterator);// \n//     }\n// }\n\n\n// //scanCircle(jimpImage, 92, 170, 43, 0x000000FF);\n// //scanCircle(jimpImage, 92, 170, 42, 0xFFCC00FF);\n\n// function clamp(value, min, max) {\n//     return Math.min(Math.max(value, min), max);\n// }\n\n// function scanCircle(image, x, y, radius, color) {\n//     let iterator = makeColorIterator(color);\n//     return image.scan(x - radius, y - radius, radius*2, radius*2, function (pixX, pixY, idx) {\n//         if (Math.pow(pixX - x, 2) + Math.pow(pixY - y, 2) < radius*radius) {\n//             iterator.call(this, pixX, pixY, idx);\n//         }\n//     });\n// }\n\n \n\nreturn msg;","outputs":1,"noerr":0,"x":290,"y":700,"wires":[["b3dc4a3.c8005b8"]]},{"id":"ed24352e.c554d8","type":"image viewer","z":"e78eac1c.8b9cf","name":"","width":"240","data":"payload","dataType":"msg","x":750,"y":700,"wires":[[]]},{"id":"b3dc4a3.c8005b8","type":"jimp-image","z":"e78eac1c.8b9cf","name":"","data":"payload","dataType":"msg","ret":"img","parameter1":"90","parameter1Type":"num","parameter2":"RESIZE_NEAREST_NEIGHBOR","parameter2Type":"resizeMode","parameter3":"","parameter3Type":"msg","parameter4":"","parameter4Type":"msg","parameter5":"","parameter5Type":"msg","parameter6":"","parameter6Type":"msg","parameter7":"","parameter7Type":"msg","parameter8":"","parameter8Type":"msg","parameterCount":2,"jimpFunction":"rotate","selectedJimpFunction":{"name":"rotate","fn":"rotate","description":"rotate the image clockwise by a number of degrees. Optionally, a resize mode can be passed. If `false` is passed as the second parameter, the image width and height will not be resized.","parameters":[{"name":"deg","type":"num","required":true,"hint":"the number of degrees to rotate the image by"},{"name":"mode","type":"resizeMode|bool","required":false,"hint":"resize mode or a boolean, if false then the width and height of the image will not be changed"}]},"x":490,"y":700,"wires":[["93f32ac6.a25508"]]},{"id":"cfe2ee33.b5b52","type":"inject","z":"e78eac1c.8b9cf","name":"","topic":"","payload":"BQFAOEhISUlJSUhISUlJSUhISEhHR0dGRkZGRkVERERERERDQkJCQUFBQUFAPz8/ Pz4+PT09PTw8PDw7Ojk5ODg4ODg3NjY1NTU1NTMzMjIxMTEwMC8vLy8vLi4uLS0sLCwsLCsrKyopKCgoKCg oJyYmJiYlJSUlJSUlI0pKSkpKSkpKS0tMS0pJSUlISEhIR0dHRkZGRkZFRUVFRENDQ0NCQkFBQEBAQD8/ Pj4+Pj09PTw8PDs5ODg4ODg3Nzc2NjY2NTQ0NDMyMjExMTAwLy8vLy4uLi4tLCwsLCwrKyoqKSkoKCgoKCc nJiYmJiUlJSUlJUtLTEtLS0xLS0xNTEtLSkpKSklJSUhIR0dHR0dGRkZGRUVFRENDQkJBQUFBQEBAQEA/ Pz49PTw8PDs7Ojk5OTk4ODg3NjU1NTU1NTMzMzIyMTExMDAvLi4uLi4tLCwtLSwrKysrKiopKSkoKCcnJyc mJiYlJSMjI0xMTU1NTU1MTExNTU1NTExMTEtLS0pKSUhISEhHR0dHR0dGRURERENDQ0JCQUBAQUFBQEA/ Pj09PDw8Ozs6Ojk5OTk4NzY2NTU1NDQzMzMzMjIyMTEwLy8vLy8uLS0sLCwsKysrKioqKSkoKCcnKCcmJiY lJSUlJU5OT09QT09OTk5OTk5OTU1NTUxMTEtLS0pKSkpJSUlISEhHRkZGRURERERDQkJBQUFAQEA/ Pz8+Pj09PDw8Ozs6Ojk4Nzc3NjY1NDQ1NDQzMjIyMTExMDAwLy8vLi0tLSwsLCsrKioqKikpKCgoKCcnJiY lJSUlJVBQUVFRUVFRUFBQUFBQUE9OTk5OTk1NTU1MTExMS0pKSUlJSEhHRkZGRkVFRENDQkFBQUFBQEA/ Pj49PT09PDw7Ozo5ODg4ODg3NTU0NDQzMzMzMjExMTEwMC8vLy4uLi0tLCwrKysqKSkpKCgoKCcmJiYmJiU lJVJSUlJTUlJSUlJSUlFRUVFRUFBQT09PTk5NBQJAODAvLy4uLS0tLCwrKyoqKikpKCgoJycmJmFhYWBgYG BgX19fX15dXV1cXFtbW1taWVhXV1dXVlZVVFRTUlFQT09PTk1OTUxMS0tKSklJSEdGRUREQ0NDQkJBQUBAP z49PDw7Ojo6OTk4ODc3NjY1NTQzMzMyMjExMTAwLy8uLi0tLCwsKyoqKiopKSkpKCgnJ2VlZGRkY2NjY2Nj YmFhYWFfX15eXl1cW1taWllZWFhXV1ZVVFNSUVBQT09PT05NTUxLS0pJSEdHR0ZFRUVDQ0NCQkFAPz4+PT0 9PDs7Ojk4ODg3NzY2NTQ0NDMyMjIxMDAwMC8vLi4tLSwsLCwrKyoqKSkpKCgoJ2loZmdoaGdnZmVmZWRkZG NjYmJiYV9eXV1cXFxbWllZWVhXVVRUU1NSUVFRUE9PTk1MS0tKSUlJR0dGRkVERENDQ0JBQD8+Pj49PTw7O zo5ODg4Nzc3NjU1NDQ0MzIxMTAwMDAvLy4tLS0tLCwsKysrKikpKSkoKHFxcXBwb29vbWxra2ppaWdmZWVk Y2JhYGBfXl5dXFxbWllYV1ZWVVVUU1NTUlJRUE9OTk1MS0pKSEdHR0ZFRURERENCQD8/ Pz8+PT08Ozs6OTk4ODg3NzY1NTU0NDMyMjExMDAvLi4tLS0tLCwsLCsrKiopKSkoKHd3eHh3dXNxcHJzc3B sa2tqaWloZ2ZkY2NiYWBfXl5dW1pZWVhXVlZVVVRUU1NSUVBQT05NTEtLSklISEdGRkZFRURDQkFAQD8+Pj 08PDw7Ojk4ODg4NzY1NTU0NDMzMjExMC8vLy4uLi0tLCwsLCwrKiopKSkoKIWGiIqJiIeFg4KAfnx6eXd0c nFvbWppaGdmZWNhYGBfXl1cXFtaWVlYVlZVVFNTUlJSUVBPTk1MTEtKSUlIR0dHRkVEQ0JCQUA/ Pz4+PTw8Ozo5OTk4ODc2NjU1NDMzMzIyMjEwMC8vLy4uLSwsLCwrKioqKSkpKKCfBQNAOI2LiYiGhIOCgH5 8e3l3dnRycXBubWxsamhnZmVkY2FgX15dXFxbWllYV1ZUU1NSUfz8/Pz8/Pz8/Pz8/Pz7+/r5+Pf3+Pj39/ b29fX08vX48+zm4NzY1dLOy8nHxMLAvry7uba0s7GvrayqqKakop+dnJqYl5aVk5CNi4mIhoWDgX9+fHp5d 3V0cnFwbm1ta2loZ2ZlZGNiYV9eXl1cW1pZWFdVVFRTUfz8/Pz8/Pz8/Pz8/Pz8+/r5+fn5+Pj39/j39/ f39vX08vDt6ufj39rV0c/ MycbFwsC9vLq4trSysK6sqqilo6GfnZyamZmYlpOQjouKiIeFg4GAfnx6eXd2dHJxcG9tbGtpZ2ZmZWRjYm FfX11cW1taWlhWVVRTUvz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pv5+Pj39/f29vXz8/ T18u7s6uXg29fTz8zKx8TBwL68uri2tLKwraqpp6WjoJ6cm5qZmJaTkI2MiomHhYOCgH58enh3dnRycnFvb m1ramhnZmVkYmFgX15dXFtbWllXVlRTU/z8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz7+/r5+Pb39/ X2+Pf29fT09PT29O/s5+Hc19LPzMnGxMK/ vbu5t7WysK2rqainpKGenZybmpmWk5COjIuJh4WEgoB+fHp5eHZ0c3Jvbm1ramppZ2ZlY2JhYF9eXVxbWll YV1ZVVPz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/f7//v38+/n49/ X09PTz8fDv7uvm4NzY1NDMycfEwb+9u7m2tLGurKqopqOhoJ6dnJqZlpORjouKiIaEg4F/ fXx7eXd1dHNwbm1sa2ppaGdmZWRjYV9eXl1bWllYV1ZVVfz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz7+/r5+Pf29vX08/Pz8/ Lv6ubi3djSzsrHxMPBvry5trSyr62rqaakoqGfnp2bmJaTkI6MioiFg4KAfn18enh2dXNycXBuBQRAOPb29 vX19vTs4trUzcjEwb27uLWzsa+trKurqqqpp6OemJSRj42LiYeGhIKAfnx6eXh3dXNycG5sa2poZ2ZkY2Jh X15eXVtaWPz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pv7/ Pz7+fj39fT09PX07eXc1M7KxcG+vLm2s7GvrayrqqqpqKeimpWTkY+Ni4mIhoOAfn17enh3dXRyb25tbGpp Z2ZlY2JhYF9eXVxaWfz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pv6+Pj39vX08/Py8/ Ls4tnRy8bCv7y5tbOxr62rqamop6SgnJiVk5GOjIuJh4SBf358enh3dnRycG9ubWtqaWdlZGNiYWBfXlxaW fz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/P38+ff19PTz8/ X17+Ta083Hw7+7ube0sq+sqqmnpaShnZqXlZOQjouJh4WDgoB+fHp4d3V0cnFwbm1raWhmZmVjYmFgX11bW vz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pv6+Pf39vXz8vPz8Ovk3NTMx8K/vbq3tLKvrKqop6ShnpyZl5SRj42LiYeGhIF/ fnx6eHZ1dHJxb25samlnZmZkY2FgX15cW/z8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/P37+ffz8fLz8/Py69/ VzsjEwL67ubayr6yqp6SioJ6cmZaTkY+Ni4mHhYKAf317eXh2dXNxcG9ubGpoaGhmZGJhYF9eXPz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pv7+fj39vTz8/ Lw7urg1s3Hw8G+u7ezBQVAOPz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz7+vj39/ b19PLw7+zl3NPKxL+8ubazr6yppqOgnpyZl5SRkI6LiYeFgoF/fXt5d3d1c3FvbWxqaGdmZWRiYfz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8+/ n39fPx8O/s593SysO/vLi1sa6rqKajoJ6cmZaTkY+MiomHhIKBf3x6eXh2dHJwbmxraWdnZmRjYvz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz7+vn49vX19PPx7ebc0snDv7u3tLGtqqiloqCdm5iWk5GOjImIh4SBf317enh2dXNxb25sa2lnZWVkYvz8 /Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz6+Pf29fTz8O3n3NHIwr66trSxraqnpaOgnZqXlJKQjouKiIWCgX99e3l3dnRycG9tbGpoZ2ZlZPz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pv6+fj29fTz8vHt5dnPx8K+urWwrqyqp6Win5yZlpSSkI2LiIaEg4F/fXt5d3VzcXBubGtqaWhmZfz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/f39/f39/f39/ f39/fr49vTz8vLx7uTYzsfCvrq2sq+rqKWjoJ6bmZaTkY+MioiGg4F/fXt5d3V0c3JwbmxqaWdlZP39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39BQZAOP39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ fz7+fj39fX19PLw6+LVysXBvLi0sa6sqaWioJyZlpSSj42KiIaDgX59e3h2dXNxb25sav39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/Pz69fP19fPz9O/i08rEv7u4tbKvrKilop+cmZaTkY+NioiFgn9+fHl3dnVzcG5ta/39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/Pz69/b19fTz8u/o3NHIw7+7t7SwraqnpKGem5iVk5COi4iGhIF+fHp5d3VzcXBubP39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/fz8+/j29fTz8fDt5dnOx8K+urezr6yqp6SgnJmXlZKPjYqIhoOAfXx6eHZ0cnBubP39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/fz8+/n49vTy8fHy8OXWzMXAvbm2sq6sqaajn5yZlpSRj42KiIWCf317eXd1cnBubf39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/f39/fz6+Pbz8vLy8evf08rEwLy5tbGurKmmo5+bmJWTkI6MiYeEgX58enh2dHJwbvv7/P39/f39/ f39/f39/f39/f39/f39/f39BQZAOP39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ fz7+fj39fX19PLw6+LVysXBvLi0sa6sqaWioJyZlpSSj42KiIaDgX59e3h2dXNxb25sav39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/Pz69fP19fPz9O/i08rEv7u4tbKvrKilop+cmZaTkY+NioiFgn9+fHl3dnVzcG5ta/39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/Pz69/b19fTz8u/o3NHIw7+7t7SwraqnpKGem5iVk5COi4iGhIF+fHp5d3VzcXBubP39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/fz8+/j29fTz8fDt5dnOx8K+urezr6yqp6SgnJmXlZKPjYqIhoOAfXx6eHZ0cnBubP39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/fz8+/n49vTy8fHy8OXWzMXAvbm2sq6sqaajn5yZlpSRj42KiIWCf317eXd1cnBubf39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/f39/fz6+Pbz8vLy8evf08rEwLy5tbGurKmmo5+bmJWTkI6MiYeEgX58enh2dHJwbvv7/P39/f39/ f39/f39/f39/f39/f39/f39BQdAOLe0sa+sqKSfnJmWko6MioeEgn98eXd1cu3w8vLx7vHv5ebp6e73/ f37+/z8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz7+ff39vX08/Ht5dvSzMW+uLe2s7CtqqWhnpuXlJGPjImHhIB+fHl1c/Ly8fPy6unl3OHn49/i6/ D3/f79/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8+/r59vX09PPw6uHY0cvFwLy4tbKvrKikoJyZlpSSj4uHhIJ/fHl2dPf4+v379/Tz8erm5t/ j7+7w9fX1+Pv8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8+/r59/b09PPy7+je1s/JxcC7uLSxramloZ6al5WTkIyIhYOAfXp5dvr7/Pv6/ Pz49fHt6OPq8+7r7fH1+v7+/fz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pv6+ff18/Pz8e7m3NPMx8PAvLeyr6unpKCcmZaUkYyJhoSBfnx6d/v7/Pz8+/ v6+Pn48Orr7ezi4vP9+vX1+fv8+/v8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pv7+fj18/Ly8e/q4tnRysbDvrizsK2qpqKfm5iVkY6Kh4SCf316d/z8/Pz8/ Pz7+fbz8O3s7u3m4N/i6O70+fv7+/v7/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8+/ n39fPy8vHu6ODXz8rGwby4tbGsqKSgnJmVko+MiYaDgX57ePz8BQhAOP39/f39/f39/f39/f39/Pv59/ f29PLw7enm4dnRy8W/urWwqqWgm5iUkY2Kh4SCf/39/f39/f39/f39/f39/f39/f39/Pz7+/z9/vz6+fr8/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ Pv5+Pf39fPy8e7p497Y0MnDvbexraijnpqXk4+LiIWCf/39/f39/f39/f39/f39/f39/f39/f38/ Pv7+PPx9/v8/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/fz8+vj39vXz8e/s6OXg2dHKxL64s62noZ2ZlZGNiYaDf/39/f39/f39/f39/f39/f39/f39/f38/ Pv49fT4/P79/Pz9/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/fz7+Pj39vX08vHu6+fj3dbQysS+uLKspqCbl5OPi4eEgf39/f39/f39/f39/f39/f39/f39/f39/ Pr4+Pn59PL2+vz9/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/fz8/Pv59/f29fLu6+nm4tzVz8rEvbexq6WfmZWSjoqGgv39/f39/f39/f39/f39/f39/f39/f39/ Pv6+PLq6/L2+/z9/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/fz8+/r5+fj39vPw7uvp5eHb1M3Hwbu1r6minZiUkIuHg/39/f39/f39/f39/f39/f39/f39/f39/ Pz69u/u9fv8/fz9/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/f39/Pz7+/n39vTyBQlAOP39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f38/Pz7+fb18/Du7uzq6OXj4NzX0crFv7myq6Oclf39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ Pz8/Pz9/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/Pv59/Xz8vHv7u7s6ujm5ODb1M7Iw722r6igmP39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ Pz7+/n4+Pb08/Hv7e3t6+ro5uPd19LMx8G7ta2knf39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ Pz7+vn49/b18/Hv7u3s6+vq5+Pf2tXPyMK8trCpov39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/f39/ f38/Pv39PT19PLv7+7t7Ozq6OXi3tnSzMbAurStpv39/fz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz7+fb09PT08vHw7u3t7Oro5uTh3djTzsnCu7Wtpvz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz 8BQpAOPz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pv6+PX08/Pz8e7r6efm5+np6Ofl5OTh3djSy8S+t/z8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pv7+fj29PLy8/Hr5+Xl5ebn5+bk4+Lf3NfSzMbAuPz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz7+/j08vLy8O7p5ePj4+Tl5eXj4uHf3NfSzcfAufz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz7+PX08/Px8O3p5OHg4eLk5eXk5OTh3dfSzcjCuvz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz7+fb08/Ly8e7p4t7d3d/h4+Xm5OPh3dnUz8rEvPz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz7+fb08/T19O7n4Nza2tze4eLj4+Lg3drW0crEvvz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8BQtAOPz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz7+vf08vLy8e/o3tbS0dLU19rd4OLi4d7a1tLNyPz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/Pz8/ Pz8/Pz7+Pb19PLx8e7o3dTR0NDS1djc3+Hi4d/ a1tLNyEVORCAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC AgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgI CAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICA gICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIC AgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgI CAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICA gICAgICAgICAgICAgAwA7MTA6MjM6MzA7MTsyMy43Ozk5OTk7MjEuMjs5MDs2NTswOzQ4OzExMzsxMjYyOT syMjA7MTI7OTk5OTsxODE7MDs4MTkyOzE5NDYxNTcwNTg7NTY7MjA1OzI1NTs0MDs2OTsxMDYwMi47MDswO zE7MTs0Ljc1Ow==","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":270,"y":580,"wires":[["d6e8b32e.3f4f4"]]},{"id":"93f32ac6.a25508","type":"jimp-image","z":"e78eac1c.8b9cf","name":"","data":"payload","dataType":"msg","ret":"img","parameter1":"2","parameter1Type":"num","parameter2":"RESIZE_NEAREST_NEIGHBOR","parameter2Type":"resizeMode","parameter3":"","parameter3Type":"msg","parameter4":"","parameter4Type":"msg","parameter5":"","parameter5Type":"msg","parameter6":"","parameter6Type":"msg","parameter7":"","parameter7Type":"msg","parameter8":"","parameter8Type":"msg","parameterCount":1,"jimpFunction":"gaussian","selectedJimpFunction":{"name":"gaussian","fn":"gaussian","description":"Gaussian blur the image by r pixels (VERY slow)","parameters":[{"name":"r","type":"num","required":true,"hint":"the pixel radius of the blur"}]},"x":620,"y":700,"wires":[["ed24352e.c554d8"]]}]
