# Unable to get audio out of 3.5mm jack
**URL:** <https://discourse.nodered.org/t/unable-to-get-audio-out-of-3-5mm-jack/58580>\
**Created:** [18 February 2022 07:04 UTC](https://discourse.nodered.org/t/unable-to-get-audio-out-of-3-5mm-jack/58580 "2022-02-18T07:04:22Z")\
**Post date:** [18 February 2022 11:41 UTC](https://discourse.nodered.org/t/unable-to-get-audio-out-of-3-5mm-jack/58580/2 "2022-02-18T11:41:32Z")
Welcome to the forum Mark!
Did you make sure to set the audio settings (per the [readme](https://flows.nodered.org/node/node-red-contrib-speakerpi) for the node)?
did you try - outside or NR - to play audio?
what file format did you send to the node?
What version of Node-RED and node.js are you running (take a look at the NR startup log to get this)
I just tried it and it works for me.
Please export your flow and attachet to a reply:
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/unable-to-get-audio-out-of-3-5mm-jack/58580)._
