# Unidentified error message
**URL:** <https://discourse.nodered.org/t/unidentified-error-message/96543>\
**Created:** [13 April 2025 07:20 UTC](https://discourse.nodered.org/t/unidentified-error-message/96543 "2025-04-13T07:20:07Z")\
**Post date:** [13 April 2025 10:57 UTC](https://discourse.nodered.org/t/unidentified-error-message/96543/4 "2025-04-13T10:57:51Z")
You really haven't provided enough information. What are the nodes you are toying with?
What version of NR and node.js are you using? (check the NR startup log)
Are you using Docker or Home Assistant?
Can you provide your flow so we can take a look a it?
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/unidentified-error-message/96543)._
