# Update JSON Data with another node
**URL:** <https://discourse.nodered.org/t/update-json-data-with-another-node/44642>\
**Created:** [24 April 2021 05:38 UTC](https://discourse.nodered.org/t/update-json-data-with-another-node/44642 "2021-04-24T05:38:10Z")\
**Post date:** [24 April 2021 06:05 UTC](https://discourse.nodered.org/t/update-json-data-with-another-node/44642/2 "2021-04-24T06:05:21Z")
Hi, I can offer you a solution using a function node easily enough but I suspect when you come to use this in a real world situation you wont be injecting values & the solution might not be that useful.
The issue is messages never travel at the same time so you either have to store the "person" for later modification or use a join node. For demonstration purposes I'll store the "person" in flow context.
Any how, I suspect you are more interested in the function code - essentially you can loop through the keys and assign the value from your payload to the other object.
Object.keys(msg.payload).forEach(e => {
    msg.person[e] = msg.payload[e];
msg.payload = msg.person;
alternatively you can use [`Object.assign`](https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Object/assign)
msg.payload = Object.assign({}, msg.person, msg.payload);
Here is a demo...
[{"id":"848f43d2.e6e2d","type":"inject","z":"dd03fa8d.2f4be8","name":"bill","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"name\" : \"bill\", \"age\" : 11, \"address\" : \"old street\" }","payloadType":"json","x":710,"y":600,"wires":[["56d4d9bc.9a1a58"]]},{"id":"dbaa0e8.4ed62f","type":"inject","z":"dd03fa8d.2f4be8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"age\" : 13 }","payloadType":"json","x":730,"y":700,"wires":[["3fcaa36.a4a9d5c"]]},{"id":"d8bbac91.bc274","type":"inject","z":"dd03fa8d.2f4be8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"height\" : 1.24 }","payloadType":"json","x":740,"y":820,"wires":[["3fcaa36.a4a9d5c"]]},{"id":"56d4d9bc.9a1a58","type":"change","z":"dd03fa8d.2f4be8","name":"","rules":[{"t":"set","p":"person","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":620,"wires":[["c8e5b450.5f6978"]]},{"id":"5001aa48.838754","type":"function","z":"dd03fa8d.2f4be8","name":"v1","func":"if(!msg.person) return null;\n\nObject.keys(msg.payload).forEach(e => {\n msg.person[e] = msg.payload[e];\n})\nmsg.payload = msg.person;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1150,"y":760,"wires":[["947a602b.b0eb2","54a09ccc.078a64"]]},{"id":"3fcaa36.a4a9d5c","type":"change","z":"dd03fa8d.2f4be8","name":"","rules":[{"t":"set","p":"person","pt":"msg","to":"person","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":760,"wires":[["5001aa48.838754"]]},{"id":"53161ace.08ffa4","type":"inject","z":"dd03fa8d.2f4be8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"age\" : 14 }","payloadType":"json","x":730,"y":740,"wires":[["3fcaa36.a4a9d5c"]]},{"id":"9a0d21bd.0837","type":"inject","z":"dd03fa8d.2f4be8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"height\" : 1.23 }","payloadType":"json","x":740,"y":780,"wires":[["3fcaa36.a4a9d5c"]]},{"id":"947a602b.b0eb2","type":"debug","z":"dd03fa8d.2f4be8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1330,"y":800,"wires":[]},{"id":"c8e5b450.5f6978","type":"debug","z":"dd03fa8d.2f4be8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1330,"y":620,"wires":[]},{"id":"23fca80c.3aaef8","type":"inject","z":"dd03fa8d.2f4be8","name":"ted","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"name\" : \"ted\", \"age\" : 12, \"address\" : \"new street\" }","payloadType":"json","x":710,"y":640,"wires":[["56d4d9bc.9a1a58"]]},{"id":"72ffc8c0.bb55e8","type":"function","z":"dd03fa8d.2f4be8","name":"v2","func":"if(!msg.person) return null;\nmsg.payload = Object.assign({}, msg.person, msg.payload);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1150,"y":940,"wires":[["f076a1fd.66a2","2b0c0d7.5f996f2"]]},{"id":"54a09ccc.078a64","type":"change","z":"dd03fa8d.2f4be8","name":"","rules":[{"t":"set","p":"person","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1340,"y":760,"wires":[[]]},{"id":"f076a1fd.66a2","type":"change","z":"dd03fa8d.2f4be8","name":"","rules":[{"t":"set","p":"person","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1340,"y":940,"wires":[[]]},{"id":"2b0c0d7.5f996f2","type":"debug","z":"dd03fa8d.2f4be8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1330,"y":980,"wires":[]},{"id":"80416174.bd45b","type":"inject","z":"dd03fa8d.2f4be8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"age\" : 13 }","payloadType":"json","x":730,"y":880,"wires":[["20940385.4525ec"]]},{"id":"62e7cf46.95886","type":"inject","z":"dd03fa8d.2f4be8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"height\" : 1.24 }","payloadType":"json","x":740,"y":1000,"wires":[["20940385.4525ec"]]},{"id":"20940385.4525ec","type":"change","z":"dd03fa8d.2f4be8","name":"","rules":[{"t":"set","p":"person","pt":"msg","to":"person","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":980,"y":940,"wires":[["72ffc8c0.bb55e8"]]},{"id":"fa35f570.91fb08","type":"inject","z":"dd03fa8d.2f4be8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"age\" : 14 }","payloadType":"json","x":730,"y":920,"wires":[["20940385.4525ec"]]},{"id":"2a80c7e1.183828","type":"inject","z":"dd03fa8d.2f4be8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"height\" : 1.23 }","payloadType":"json","x":740,"y":960,"wires":[["20940385.4525ec"]]}]
_[View the full topic](https://discourse.nodered.org/t/update-json-data-with-another-node/44642)._
