Uploading data to a mySQL database
right thats what i did. I set the debug node to display the complete msg object but it is still showing this error:
"Invalid property expression: unexpected ' at position 4"
which is pretty strange because is shoeld be seeing the query in the msg.topic right?
I did untill i changed my query to this thanks to the help of @shrickus
INSERT INTO algemeen
    (machine, persoon, status, overtime)
VALUES
    {{ flow.get('machine') }},
    {{ flow.get('persoon') }},
    {{ flow.get('statusGoed') }},
    {{ flow.get('overtime') }}
but i should not be getting permission denied errors because the users has all of the permisions.
I can't try a new client as of right now because the server running on a server and not on my laptop
The syntax for flow context is not correct for the template node. Try
VALUES
    {{flow.machine}},
    {{flow.persoon}},
    {{flow.statusGoed}},
    {{flow.overtime}}
It is possible to use a property from the flow context or global context. Just use {{flow.name}} or {{global.name}} , or for persistable store store use {{flow[store].name}} or {{global[store].name}}
right. well your solution seems to work a bit better but it is still giving me an syntax error for some reason:
Flow.persoon seems to be blank does it exist, the error seems to be the 2 commas in succession.
value is missing in the query
well flow.persoon definitly exists but i removed it anyway. got a new error though:
"Error: ER_BAD_FIELD_ERROR: Unknown column 'S' in 'field list'"
Should the strings be in quotes?
[edit]
I see at least two strings in your query.
Yes must have "S-110-1"
right so how do i do that?
because this is my query
VALUES
        {{flow.machine}},
        {{flow.overtime}}
and this is the output im gettinh:
VALUES
so where should i put the "?
First you need to confirm the flow context exists check in info pane under context . refresh the flow context and post here.
quotes go around strings
        '{{flow.machine}}',
        '{{flow.statusGoed}}',
        {{flow.overtime}}
and remove persoon from columns
oh i'm dumb
i forgot to remove "persoon" -_-
right it seems to work now. i'm going to need to experiment some more before i close this topic. But for now i'd like to thank all of you for the help i've gotten.
