Usb port reading problem
Start Node-RED
2 Mar 07:13:44 - [info] Node-RED version: v3.0.2
2 Mar 07:13:44 - [info] Node.js version: v16.19.1
2 Mar 07:13:44 - [info] Linux 4.19.0-23-amd64 x64 LE
2 Mar 07:13:44 - [info] Loading palette nodes
2 Mar 07:13:44 - [info] Settings file : /home/jeedom/.node-red/settings.js
2 Mar 07:13:44 - [info] Context store : 'default' [module=memory]
2 Mar 07:13:44 - [info] User directory : /home/jeedom/.node-red
2 Mar 07:13:44 - [warn] Projects disabled : editorTheme.projects.enabled=false
2 Mar 07:13:44 - [info] Flows file : /home/jeedom/.node-red/flows.json
2 Mar 07:13:44 - [info] Creating new flow file
2 Mar 07:13:44 - [warn] Encrypted credentials not found
2 Mar 07:13:44 - [error] Uncaught Exception:
2 Mar 07:13:44 - [error] Error: listen EADDRINUSE: address already in use 0.0.0.0:1880
at Server.setupListenHandle [as _listen2] (node:net:1463:16)
at listenInCluster (node:net:1511:12)
at doListen (node:net:1660:7)
at processTicksAndRejections (node:internal/process/task_queues:84:21)
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
Please do what I asked, run both commands I suggested, and post the full output including the commands entered.
Also, that is not the node red setup that you normally run, as there is no flows file at that location.
@RemyH did you work out what the issue was?
Salut
No, not al all
but as I don't understand what you need to help me, I gave up
You did not understand what I meant by running
node-red-stop
node-red-start
and posting the full output here?
Also I pointed out that node-red-start tried to open a new flows file, so you can't be using the usual method of starting node-red when you get the error you posted.
